Bent Loader Bucket
/ Bent Loader Bucket #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
I added a thumb to my bucket. Went for a test and bent the top of my bucket about 2-3 inches up. Tried attaching a chain and using bucket to pull back down with no luck. Just looking for some ideas before taking to welding shop and having entire top cut and replaced.
Eddie
/ Bent Loader Bucket #2
May need heat and a hydraulic press to put back in place. The upper edge of a bucket is not very strong as you discovered. It will need to be reinforces quite a bit to support a thumb. I reinforce all my buckets and I don't use a thumb. Eventually they all bend anyways.
andy
/ Bent Loader Bucket #3
Heavy duty "C" clamps and sturdy angle should straighten that out.
Tighten the clamps to pull the bend inwards with an occasional wack with a sledge hammer to coax the bend back.
You could also cut the flange before bending back and once straight re-enforce with a welded in place angle/doubler.
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
PORTA POTTY (A67714)
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A69167)
2005 MACK CXN613...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
