Rotary Cutter Bend rock jumper?
/ Bend rock jumper? #1
mtk51
Bobcat 863
One of the guys hit a rock a few days ago and snapped the output shaft of our 60" woods mower. It looks like the rock jumper disc is also pretty banged up.
Anyone know what the blades alignment should look like?
I have attached a picture showing a 2x4 clamped to one blade. The cutting edge is not parallel to the surface of the disc. Should it be?
If I push the end of the board down to make it parallel to the disc, the other blade is still not looking good.
Mark
/ Bend rock jumper? #2
Yeah the blades should be parallel to the stump-jumper surface. They
are not expensive at all (AgriSupply), if they are severely bent. If
your stump-jumper is too distorted, you may want to replace that, too.
I just had this 5-footer delivered here from TractorSupply the other day.
This is forklift damage, requiring a new stump-jumper. The TSC folks
caught a tine between the carcass and the jumper and bent it down. I
lift these units with a boom, from the top.
/ Bend rock jumper?
Thanks - I'll try some sledge hammer work and see if I can flatten the stump-jumper enough.
Tried digging out the rock. I'm down 3 feet and the rock is still getting bigger. I think it might be a good place to pound a fence post into the ground and drive around it.
/ Bend rock jumper? #4
I'd like to think that reincarnation is real, I just really hope that I don't come back as a bush hog!
/ Bend rock jumper? #5
We've got some "rocks" like that around here....They barely show above ground, but they can be under 1/3 of the county and 200' thick.! Mostly limestone. They're what gives this area a naturally "sweet" ph level that makes the grass appear "blue" in certain conditions....Hence, the Bluegrass State.
You might want to check on the price of the stump jumper. I replaced one on a Woods MD172 (model prior to the BB720) That was 7 years ago, but the stumpjumper was less than $150.
/ Bend rock jumper? #6
I never bought one before, and I can not get a quotation off the
BehlenCountry.com (CountyLine) website. I know Woods is expensive....
it's a total guess that I could get one for under $100, shipped or picked up.
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
1000bu FEED BIN (A64277)
1000bu FEED BIN...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2012 Palomino Ultra-Lite Camper Trailer (A66285)
2012 Palomino...
