Beekeeping
/ Beekeeping #381
Got 46 frames built today... ONLY about 100 more to go on this run 😩
/ Beekeeping #382
Picked up this nice little DW735x today for $400! And, it's a type 1, not 12, so Taiwanese and not Chinese built. Like new, with the stand. This will make truing up some lumber a lot easier and thusly assembly more enjoyable, and improve quality.
Cleaned and waxed the tables, and adjusted them. No snipe. Rock solid unit!
/ Beekeeping #383
Congratulations on a great score!
Does it have knives or the carbide cutters?
All the best,
Peter
/ Beekeeping #384
All the best,
Peter
Three knife head, two feed speeds, auto carriage lock, came with a new set of blades. There is a helical available, but that is down the road
/ Beekeeping #386
Going to flip the blades today and clean the rollers. I don't think the previous owner did anything aside from plug it in
/ Beekeeping #388
Flipped the blades on the planer, cleaned the rollers with mineral spirits, and adjusted the table a little more. Wow, those blades were dull! Sounds and cuts so much better!
/ Beekeeping #389
Specifically, why would bees store pollen? Thought honey was the primary food storage...
/ Beekeeping #391
Played with the planer today, truing up some 2x6, and cutting some side bars. Wow, working with flat wood is amazing.
Also, insulating and closing up hive floors.
Also got to test the run out in my job site saw while doing so. After ripping a 2x6 (10) times, the scrap at the end only varied in thickness from one end to the other by .015".
Incredible
/ Beekeeping #394
Gorgeous! (And I love the work table)
All the best,
Peter
/ Beekeeping #396
That work table was an awesome project. All pocket screws. You can't see a single fastener, except on the table top.
I noticed. Gorgeous! What coating did you put on it?
I also noticed how pristine the top is. 😀
All the best,
Peter
/ Beekeeping #398
Several layers of Shellac. Very durable
I have often used a 50/50 mix of shellac and linseed oil. Gorgeous, but it benefits from many, many coats. I'm not sure that I would use it on a workbench.
All the best,
Peter
/ Beekeeping #399
All the best,
Peter
The top is 3/4 MDF... So this gave it a nice hard shell for longevity.
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
2018 SKYJACK SJ843 TELEHANDLER(INOPERABLE) (A65643)
2018 SKYJACK SJ843...
2022 EZ-GO ELITE...
2016 Ford F-150 Pickup Truck, VIN # 1FTEW1EG0GKE69622 (A65563)
2016 Ford F-150...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
