Battery Tray Restore
/ Battery Tray Restore #1
ETpilot
East Texas
My tractor battery developed a short and would discharge overnight. I bought a replacement and when I removed the old battery I knew I had to do something about the battery tray. It was all rusted and coated in battery corrosion dust. So a restore was in order. I removed the tray, wired wheeled the exposed areas and brushed the hard to access areas. I then used aircraft acid proof battery box paint. I have used this paint with good results. I feel it will help this tray live a little longer. I may have to fabricate the right side battery hold down bar as it was pretty well eaten away. It may hold for a while longer. The paint should help. Anyway, thought I would share some pics. The paint is high gloss so the last picture shows the grass reflection and does not show the black finish too well.
/ Battery Tray Restore #3
I wanted a metal tray for my old Kubota. The rust had eaten the original and two license plates that made up the bottom. I found a Square D electrical panel box in the scrap and it became a perfect heavy gauge battery box. A little cutting and a few mig welds plus a heavy mud flap bottom (to reduce virbration) and I was back in the fields.
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
2021 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2021 GMC Sierra...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
