battery not charging
/ battery not charging #1
stykemainb
Davisboro,Georgia
JD X500, JD M 40T Tricycle
I just charged up my battery for my x500 and after a couple of hours or so the tractor stops and the battery is dead again but after I charg the battery it starts again any Ideas? Could it be the voltage regulator?:confused:
/ battery not charging #2
If it's under 4 years old, it's still under warrantee... If not, you'll need to grab a meter & start troubleshooting the problem. I've seen some good troubleshooting videos on Youtube. Might be a good place to start.
If your battery is more than 3 years old it is definitely suspect.
/ battery not charging #3
Check for loose fan belt, a wire pulled loose by a limb or stick, or corroded or loose battery cable at one end ,possibly at the ground to frame.
/ battery not charging #4
Take the battery to a local Autozone and have it tested for free. They will do the same for your alternator. It does sound as though the tractor is running till there is no electric.
/ battery not charging #5
Put a volt meter on the battery post's, not the end cables,
check for a charging voltage when running, if its not charging, your regulator or alternator could be gone.
/ battery not charging #9
What is the battery terminal voltage at slow and fast idle? Sounds like a total failure to charge. Any chance the battery was low this spring and somebody boosted the tractor to start ?
/ battery not charging #10
Had the same problem on my Ford toward the end of this past Winter. Discovered a plug connection that had a little dirt/corrosion. A little cleaning and it was back to normal.
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
NEW HOLLAND PULL TYPE ROLL BAR HAY RAKE (A64278)
NEW HOLLAND PULL...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2022 EZ-GO ELITE...
JOHN DEERE 4730 SPRAYER (A64278)
JOHN DEERE 4730...
