Bathroom Re-model concrete foundation
   / Bathroom Re-model concrete foundation #41
That's an interesting bathtub. Do you walk into it, sit down, close the door, then start filling it up while sitting there? How long does that take? I guess the same happens when you are done? you open the drain and wait for the water to go away before you can leave it?
Yes....that's the process.
Fills pretty quick. Has 3/4" lines that connect directly, compared to the typical 1/2" lines on a shower valve, which are further restricted by govt mandated low flow shower heads.
On the drain, it has a power pump motor + the typical tub drain. Will drain in under a minute. You're still plenty warm from the bath by the time it's done. Has two other motors for water circulation and an air pump.
   / Bathroom Re-model concrete foundation #43
That's a lot faster then I was thinking.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2010 Ford Edge AWD SUV (A55758)
2010 Ford Edge AWD...
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
Giyi 27" Mixing Bucket (A53316)
Giyi 27" Mixing...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
Ford 600 Tractor (RUNS) (A50775)
Ford 600 Tractor...
