"batch" processing of jpegs?
/ "batch" processing of jpegs? #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
\"batch\" processing of jpegs?
Is there a web site or software out there that I can batch process a bunch of jpegs.
Ex I took a bunch of pics on vacation at high res. I want to resize them & optimize for small file size to email. Can I do them all at once? Opening them individually in adobe photoshop elements takes a while.
Thanks
/ "batch" processing of jpegs? #2
Re: \"batch\" processing of jpegs?
My version of photoshop elements (original release, I think)allows resizing a batch. Go down from "file" to "automate" then to "batch" and a window will open. Maybe that was dropped in the later version.
What I would like to find is a way to do the auto levels and auto contrast on a batch when I am not interested in tweaking each one.
/ "batch" processing of jpegs? #3
Paint Shop Pro does batch processing.
/ "batch" processing of jpegs? #5
ACDSee version 5.0 or later, Graphics Workshop, and ImageRobot come to mind. I prefer ACDSee from ACDsystems. /forums/images/graemlins/cool.gif ACDSee 6.0
/ "batch" processing of jpegs? #7
Second the recommendation for IrfanView. Does a great job of batch processing. You can also sharpen, lighten etc. at the same time.
/ "batch" processing of jpegs? #8
There are a number of "resizer" programs. Check out http://www.showyourphotos.com/
or check out shareware.com for photo converters.
thanks reb - it was right there in front of me. I did actually read the manual, but that was 1 year ago.
/ "batch" processing of jpegs? #10
I use both ACDsee and Irfanview. They're a little different so I keep them both.
IView is free, and so I'd recommend it if it will do your work. One particular featrure I treasure is that it will write the HTML to turn a set of pictures into a contact sheet with links to the large pix. I use that all the time to distribute photos. It impresses the hell out of people to be able to send them an HTML in a few minutes. <grin>
ACDSee tends to want to take over your computer, but it has a good utility to scan directories for duplicates. It's about a fifty buck program IIRC.
Both a re a little easier to use and less ponderous than PhotoShop but neither holds a candle to the big software in terms of capability.
/ "batch" processing of jpegs? #11
Hazmat--you're a better man than I am. Admitting I read an instruction manual is almost like letting the wife find out I asked someone for directions in a strange town. /forums/images/graemlins/grin.gif
/ "batch" processing of jpegs? #12
I recommend a program called ThumbsPlus (www.cerious.com). I've used it for almost ten years; it just keeps getting better. You can try it for free. It catalogs images and video, does great retouching (everything but layering, really), and has a sophisticated batch processor with a simple interface. You can do things like: "take all the photos I've selected, resize to 640 x 480, remove the redeye, apply a sharpen filter, and save in a child folder as .GIF files with a '_sm' appended to the filename." You can do it faster than you can say it.
Can't recommend it highly enough.
