Ballast to prevent overloading of front axle
   / Ballast to prevent overloading of front axle #21
How many tractors do you own having one axle?
This comment proves your lack of understanding. You could have 30 axles if they are all fixed the the frame (and for simplicity we will assume tires do not compress) and if I add weight to one end the fulcrum moves from the other end closer to the end I’m adding weight. Mathematically you could have 10,000 pounds in the FEL and add 1# behind the 30th axle and find out exactly where the fulcrum is.
Spoiler alert, on any tractor on the market the fulcrum is somewhere between the two axles and moves constantly depending on what you’re doing with each end of the tractor.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2023 Deere 325G (A60462)
2023 Deere 325G...
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
