Ballast to prevent overloading of front axle
   / Ballast to prevent overloading of front axle #1
bdog
Elite Member
Texas
John Deere 6130M
I have enough weight on my rear tires that tipping is not a concern. That being said looking at the physics of it weight in the rear tires does nothing to alleviate load on the front axle, and could even make it worse. A ballast box or heavy 3pt implement behind the tractor would however reduce the load on the front axle. Curious how big of a deal this is. Normally I have something on the back of the tractor but many times it is light enough that it probably isn't doing much.
   / Ballast to prevent overloading of front axle #2
You've got the right idea. Always have rear ballast when doing fel work. Loaded rears help keep the back end planted, where as 3 point ballast creates a fulcrum at the rear axle which takes some of the load off of the front axle.
   / Ballast to prevent overloading of front axle #3
This is debated a fair bit. If the front axle is considered to be the fulcrum rear ballast does nothing to reduce the front axle load.
If you have enough rear ballast then the rear axle becomes the fulcrum point.
   / Ballast to prevent overloading of front axle #5
I've done FEL loader work with and without something attached to the 3pt hitch and loaded the bucket on my small tractor to the point that I would need to put it in 4x4 and I have never had a problem, maybe I have just been lucky.
   / Ballast to prevent overloading of front axle #6
In my younger years I once got a bushhog stuck under a very large fallen tree. My much younger years I assure you. When I couldn't get it out driving straight forward I tried to wiggle it out by raising and lowering the hog. I would raise the hog and the front end of the tractor would come completely off the ground then drop the hog and pop the clutch. Each time I would gain a few inches forward. I finally got the mower out. This was back in the late seventies or early eighties and that mower finally died last fall. I hadn't thought of it before but that is probably why the back wheel fell off later that year.
Anyway, consider the tree as ballast hanging off the 3-pt and I can see how adding weight BEHIND the rear wheels will take weight off the front axle and put less strain on it...... Unless you keep popping the clutch and banging it on the ground. That late sixties to early eighties Ford equipment was tough.
RSKY
   / Ballast to prevent overloading of front axle #7
I like rear ballast for FEL Work.... about 500-600 pounds....
20190513_134020-jpg.604578
20190513_134501-jpg.604577
JD mower is 540 lbs by JD specs... Yes there is a low bumper on front of dead deere that is wedged under bucket lip....
   / Ballast to prevent overloading of front axle #8
"Yes there is a low bumper on front of dead deere that is wedged under bucket lip...."
You shouldn't have told us this. I was trying to figure out how the Deere was balancing so perfectly!
   / Ballast to prevent overloading of front axle #10
I find it comical (and disturbing) what people do with small tractors and they actually survive. I'd never to that crap with my big tractors, never.
   / Ballast to prevent overloading of front axle #11
For years I went along without rear ballast, just loaded tires. I got a ballast box about 4 years ago and it helps a lot. Loaded tires don’t load the front axle at all nor the rear axle. Rear ballast will take quite a bit of weight off the front axle when doing end loader work.
   / Ballast to prevent overloading of front axle #12
I agree rear tire/axle ballast doesn't lower FEL weight on frt axle BUT weight on 3 pt hitch definitely lowers weight applied to frt axle/tires. Several yrs back I took my Kubota M7040/FEL/rear bale fork & 2 rd bales to a public scale. i weighed my tractor with & without a bale on 3 pt. I located the tractor weighting info shown below. According to my research frt axle WITHOUT 3 pt counter balance exerts 610 more #s on scale.
My M7040 & LA1353 loader with cast rear wheels weighs 7670#s
Same tractor/loader with bale on frt & rear 9630#s
Frt bale weighs 1090#s
rear bale weighs 870#s
Frt axle with bale on frt and bale on the rear 5380#s
Frt axle with bale on frt no rd bale on the rear 5990#s
   / Ballast to prevent overloading of front axle #13
I have RimGuard loaded rear tires. And a 1010# Rhino rear blade on the 3-point. I don't have the rear blade back there to SAVE the front axle. It's there so I can maintain rear tire traction when lifting loads with the grapple. The front axle is designed to carry a max specific load - I never get anywhere near that limit.
   / Ballast to prevent overloading of front axle #15
RSKY
This is the perfect example of rear 3 point hitch taking weight off front axel. An extreme example but makes the point.
Years ago when I had an 8n ford tractor if I lifted my bushog going uphill the front got so light I couldn't steer. Same effect.
The front axel is the fulcrum for the FEL weight. The rear axel is the fulcrum for the 3 point hitch weight. FEL is trying to pry the back up while the hitch weight is trying to pry the front up
   / Ballast to prevent overloading of front axle #16
Bdog, good thread -- this always deserves more conversation.
Let m = weight on your 3 pt hitch.
Let L1 = the horizontal distance between that weight's center of mass and your front axle.
Let L2 = the horizontal distance between your rear axle and front axle.
You will reduce the load (weight) on your front axle by an amount m*((L1/L2) - 1).
That's one reason why behind-the-tractor ballast is so important for FEL work. As you correctly surmise, rear tire ballast (weights or fluid) will do nothing to alleviate front axle load although it has other beneficial effects sometimes.
   / Ballast to prevent overloading of front axle #18
Traditional lever diagrams are wrong for a tractor, which has two "fulcrums."
Bruce
Exactly my point from above. And we both have enough education and experience to understand your illustration is significantly different from those posted earlier with one fulcrum.
   / Ballast to prevent overloading of front axle #20
Seems to me. . .
allow me some assumptions in a make believe case.
Given
The distance from the bucket to front axle is 3', the distance between axles is 5' and the distance from the rear axle is 3'
If your counter weight was 0 and the bucket weight was 500lbs
There would be a moment of 3ft * 500lbs or 1500ft-lbs around the front axle
To offset that, the rear axle down force required for that moment would be 1500ft-lbs / 5ft or 300lbs would be relieved from the down force on the rear axle.
Don't believe that? Keep adding weight to the bucket until the rear wheels come off the ground (essentially putting 0 weight on the rear axle)
Putting counterweight on has exactly the same effect on the front axle.
Hey, I've been out of school a long time, I could be wrong but I don't think so.
1998 MACK DUMP TRUCK (A60430)
1998 MACK DUMP...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
