Ballast box
/ Ballast box #51
The pins are a Tractor supply CAT 1 "drawbar" . And yes, Concrete in the barrel. The uprights are just chunks of 4 inch angle iron I had in the scrap pile. The 2 inch receiver is also welded and attached to the drawbar with a 5/8 piece of all thread, and some 5/8 rebar also welded on an angle for stability.
CountyLine Cross Drawbar, Category 1, 3/4 in. dia. | TractorSupply
Do you have an estimate of the weight of your ballast rig with the concrete? Thanks.
/ Ballast box #52
I have a couple of alternatives. What I was originally going to do was use a scrap cultivator. I planned to cut off the ends to the size I needed, build a plywood form around what was left and pour it full of concrete. Then I could strip the form or just let it eventually rot off on its own. The cultivator would give me the 3-ph attachment points and the part embedded in the concrete would act as rebar.
Then a local contractor dropped off some pieces of what I think were once composite concrete/brick ornamental gate posts. They're various sizes, mostly a little less than 2'x2' and assorted lengths. They looked so much like the concrete blocks used as barrier, ballast etc, that I decided to use them. I picked up a 3-point hitch fork lift. It's easy to back up to one of the blocks and pick it up, then put a chain around it to hold it in place (it would be embarrassing to have it slip off the rear fork in the middle of a lift) This way I have another multi-use implement instead of just a weight. Since I have forks for the loader, I don't expect to use the rear forks very often, but they're there if I need them.
/ Ballast box #54
I made this attachment for rear forks, carry-all and the weight when needed.
Steve
bad boy zero turn 72 (A56859)
bad boy zero turn...
POLARIS RANGER XP900EFI RTV (A59823)
POLARIS RANGER...
2844 (A58376)
2844 (A58376)
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2023 FORD F-650 SUPER DUTY CAB & CHASSIS TRUCK (A59823)
2023 FORD F-650...
