Ballast Box
/ Ballast Box #1
JDGREEN4ME
Southeast PA
John Deere 2520, John Deere X534, GT 225, GT 275
I am going to take the FEL off soon and put the front blade on for snow (wishfull thinking). Do you need to keep the ballast on for the blade? Box weighs about 380 pounds. Also, when using the ballast box with the FEL I try to keep the box as low as possible, thinking this helps lower the center of gravity. Most of the tractors I have seen seem to keep the box up higher. THANKS (JD 4110)
/ Ballast Box #2
Don't think you need to keep it on, but I would expect that you would want to keep it on. But try it without the ballast. You will find out if you need it or want it as everything will all depend on the snow and the conditions. New snow that is packed is easy to get traction on, as well as when the snow is real cold. But wet snow (warmer conditions) gets to be slippery, and when it re-freezes turns to ice. Then the traction picture changes a lot, and may even get to the point that you want the ballast AND chains. You will find out that the snow and weather conditions will dictate what you need to get around.
Keeping the BB low may be good, but I don't think you can get the ballast box on the 3pt very high anyway. If on a slope, then lower is better.
/ Ballast Box #3
I have done it both ways but like the extra weight of the ballast box. My tires are not loaded so the extra weight does help.
/ Ballast Box #4
When plowing snow, you want as much weight on "your side" as possible, so I would suggest leaving the weight box on.
Although the weight box should be kept as low as possible for stability purposes, you might find when plowing snow into banks that the box might "bottom out" when the front of the tractor starts climbing up the bank. Then you'll need to raise it a bit to minimize this.
Hopefully we'll all get lots of snow this winter to practice our snow moving techniques.
~Rick
/ Ballast Box #5
Let it snow let it snow just so I can move some snow. I might withdraw that statement come Februaryand the white stuff is still coming.
2004 Quincy QSI500 Air Compressor (A61572)
2004 Quincy QSI500...
2022 John Deere MX10 (A64119)
2022 John Deere...
CATERPILLAR 299D3 SKID STEER (A64279)
CATERPILLAR 299D3...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2014 Dodge Charger Sedan (A61574)
2014 Dodge Charger...
