Planters Ballast Box
/ Ballast Box #1
onionfmr
Upstate NY
MF 1754 Cab Hydro
Recently picked up a 3 point ballast box. Dealer told me to fill it with sand. It has drain holes in the bottom. I have lots of #2 crushed stone. Looking for opinions, why couldn't I just fill it with the stone? Looks to me like sand would seep thru the drain holes in the bottom of the box? I was originally going to fill it with concrete, but, my stone is free and I really like free these days! Thanks for any and all comments Ted.
/ Ballast Box #2
Depending on the stone you have, sand is going to be much heavier than stone - Heavier is better to a point
/ Ballast Box #3
Sand is a bit heavier per cubic foot but not much. It is due to the air pockets. I'd just go with the gravel and be satisfied with it.
If you really need it heavier then you could fill it with concrete. But then we are back to the issue of cost.
/ Ballast Box #4
I like free too.So a while ago I went and put a free wanted note in the paper for no longer needed weight lifting equipment.I had a lot of people call and just say come an get em!
I fixed the bar to fit my 3 point arms,and I can add several hundred pounds when needed.
then when not needed I lower the arms and the bar can be rolled away. Yes free is good!
/ Ballast Box #5
Am in the process of buying a new John Deere 3720, and will be adding a ballast box to offset the loader. If it helps, I've uploaded sample ballast box estimated weight capacities (for that particular box). And if you're worried about sand coming out the drain holes, why not just put a piece of window screen in the bottom? Before you put in the sand of course.
//greg//
/ Ballast Box
Appreciate the replies. Thanks for the comments - Ted.
/ Ballast Box #7
I just filled mine with rocks and spent time to try to fill it tight and full to maximize weight. You could do that and fill it with sand to fill the gaps. It will work fine.
/ Ballast Box #8
Gentleman down the road from me fill his ballast box type highway mix spread on icy roads..fine grit..make sure it mix dry also cover..that way if he little extra grit for icy spots.
/ Ballast Box #9
What a really great idea, if you had all the same size weights you would have a cultipacker!
/ Ballast Box #10
I can't imagine just throwing some gravel in and out of my ballast box. I took time and worked the tractor with different weights in the ballast box, and I found the right ammount of weight that works best for my tractor, and I don't ever change it unless i am doing a different task.
If you work with getting the correct weight in your own tractor, you'll be amazed by how much more comfortable it is, as in not bucking, not spinning, not pushing the front tires, etc. Its more than just a guessing game.
/ Ballast Box #11
if you want to max out the weight you could put some rocks in the bottom to stop the sand from coming out the holes
2026 Spirit All Terrain Electric Bicycle (A61569)
2026 Spirit All...
1995 GMC TOPKICK FUEL INJECTION CHASSIS TRUCK (A62130)
1995 GMC TOPKICK...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2014 John Deere 5075E Tractor (A61166)
2014 John Deere...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
