Bad noises
/ Bad noises #1
redsput
Ym 220d and branson 4720h
I hit a stump brush hoggin and the shear pin didn't shear. Every still works, but now there's a definite broken or chipped gear sound from the drivetrain. I idled it slow to the ban and parked it. Thoughts on what it may be,and if it's likely worth fixing? At this point I'd be happy to get her going again even if the PTO is in operable. Any experience that could be shared would be greatly appreciated. Ym 220d
/ Bad noises
Note the sound is from the tractor not the brush hog in case I was unclear on that
/ Bad noises #3
Is this sound only when the pto is engaged or constant? making the noise while idling in neutral? Making the noise only when moving? need more detail.
/ Bad noises #4
Are you using a Overrun clutch? That would be a good place to look if so.
This should be the same for the YM220-226 Etc...
/ Bad noises #5
Ouch! Felt that in the seat and the pants is my guess! 220 is this it? FB.Market
2012 JLG G9-43A TELESCOPIC FORKLIFT (A64279)
2012 JLG G9-43A...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
