bad fuel on the bx23.
/ bad fuel on the bx23. #1
lawlopez
New Boson, NH
JD X450, Kubota BX23
If I leave my tractor running will it drain the battery if it sits there for 12 hours after it runs out of fuel ?
I'm trying to purge the 5 year old fuel that is in it because it is hard to start at 40F and it is smoking a lot.
Any thoughts ?
Larry in NH
/ bad fuel on the bx23. #2
Why would it sit 12 hours?
I would pay a few dollars on a cheap siphon, get the bad stuff out and refill with fresh fuel and stabilizer rather than run a bunch of known crap through it.
/ bad fuel on the bx23. #3
No need for siphon.
Just remove the hose before the first fuel filter from the tank.
/ bad fuel on the bx23. #4
Yes Indeed. Disconnect the fuel line hose before it gets to the fuel filter. Drain everything. Change the fuel filter and fill the new one with diesel before installing. Reconnect the fuel line and fill the tank with new diesel. About 90 minutes later, you should be running fine.
/ bad fuel on the bx23. #5
Any thoughts ?
Larry in NH
Syphon it out.
That's what I did once when I had to remove some wax globs at the tank outlet.
Ralph
/ bad fuel on the bx23. #6
If it's like my bx2660, there are 2 fuel filters, be sure to change both.
Thanks for the help.
I ran out the tank.
When I got to the tractor after it stopped the electrical fuel pump was still pumping.
I should have just drained the tank.
It's a bit warmer now.
It was really filling the barn with smoke.
I'll get fresh winter fuel and additive and see if that helps.
I put 1 qt of kerosene in the empty tank.
Kerosene os thinker than Diesel it runs hotter and doesn't have the necessary additives.
It stated without smoke.
When this runs out I'll fill with fresh diesel.
Starting it the other day filled the barn with smoke.
I was exiting holding my breath.
I'm allergic to diesel smoke.
/ bad fuel on the bx23. #9
Why didn't you leave it outside?
/ bad fuel on the bx23. #10
Quote:
"I ran out the tank.
I'm allergic to diesel smoke."
It's much wiser, IMHO, to ask for advice first and before you take action...furthermore, I do not understand why you wanted to run bad/contaminated fuel thru fuel system and combustion chamber??
I once added an older 5gal plastic container of diesel that had algae in it...I simply drained the tank into 5gal buckets by disconnecting fuel line prior to fuel filter bowl. Once emptied, I poured a tank cleaner into fuel tank that too drained into the plastic container. I allowed the tank to completely dry via evaporation w fuel cap off. No smoke, no need to watch tractor or other. About 2-3 hrs later, filled w good fuel and diesel fuel conditioner and was good to go....and yes, obviously I emptied the fuel bowl and changed the fuel filter...
/ bad fuel on the bx23. #11
Rather interesting...
I would change your fuel filters like now, before adding fresh fuel.
/ bad fuel on the bx23. #12
Might as well replace that burned up fuel pump while you’re at it.
/ bad fuel on the bx23. #14
I surely don't recommend you treat your Kubota BX23 to a tank full of 5 year old diesel again. Don't completely run the Kerosene out of the entire fuel system. Please put in new diesel ASAP to get that wonderful BX running properly again.
Is it ok to keep it outside ?
I kept my JD950 outside and it didn't care at all.
It was more rigged than my kubota, I think.
I need another cold day to tell if the fresh fuel is working.
I don't know how old the old diesel fuel was.
I only put it in to move the tractor around and get it to be serviced.
There was too much to fix for me to want to do.
/ bad fuel on the bx23. #16
It's ok to keep it outside but smoking out the barn why? Fuel will last years if no water is in it.. But if you keep the tractor inside it will last longer and have less problems and have a better resale value..:2cents:
/ bad fuel on the bx23. #17
^^ This is has got to be the weirdest thread I've seen in a while.
I have a feeling the OP has bad English and accidentally switched up the words.
If not, then I'm like, huhhhh?!!?!
/ bad fuel on the bx23. #18
LOL...:)
/ bad fuel on the bx23. #19
His BX has over 1300 hours on it, thats pretty good use of it. These can be kept outside but it would be good if you installed a hot plug and used Diesel treatment to keep the fuel from gelling up.
/ bad fuel on the bx23. #20
I built my first house in his town, he is not indicative of the local population.
