BAD 'BOTA!!!
/ BAD 'BOTA!!! #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
BAD \'BOTA!!!
Need some help from you cold weather pros. My B21 (1998 model/ 580 hrs.)has never failed to start, until today./w3tcompact/icons/frown.gif It has not been started in two weeks and sat out in the cold during that time. (34F Hi, 10F Low) These are temps below normal for a Georgia tractor and I am not the best mechanic you have ever met.
When I had the problem I figured the fuel was the suspect. I added a stabilizer to the tank (1/2 full) but no luck. It would turn over and did run for 5-10 sec. but then died. Jumped it with the truck, a lot of turning over, but never fired up. Anyone have an idea where I should start looking?? I sure did hate to miss my once every five year chance to blade snow./w3tcompact/icons/smile.gif
Thanks
MarkV
/ BAD 'BOTA!!! #2
Re: BAD \'BOTA!!!
Mark,
Maybe you have jell fuel in the line.
Do you have fuel flowing to your filter pot..to check open your bleeder screws.
So you have a saftey switch hidden somewhere.
Thomas..NH /w3tcompact/icons/wink.gif
/ BAD 'BOTA!!!
Re: BAD \'BOTA!!!
Thanks Thomas, Sorry for being so slow, are we talking the glass bowl below the fuel filter? I don't think I have a bleed screw, but I can pull the bowl. If the fuel has jellied, will an additive make it OK or do I need to find away to drain the tank?
MarkV
/ BAD 'BOTA!!! #4
Re: BAD \'BOTA!!!
Mark,
First: no cold weather pro here and not because it ain't cold here./w3tcompact/icons/smile.gif
Do you have the workshop manual for the B21? If not, I can help by adding the trouble shooting tips from the manual for "engine does not start". Let me know. My first guess would be the same as yours, fuel. I would check the fuel filter and the fuel line next the injection nozzles for gelled fuel.
Al
/ BAD 'BOTA!!! #5
Re: BAD \'BOTA!!!
If the fuel has jelled then you will have to change the fuel filter and fill it with fresh fuel/conditioner mix. Here is a link to a thread a couple of weeks ago. It goes into detail and gives the link to powerservice. <font color=blue>my tractor wont start</font color=blue>
Hope this helps
Gordon
/ BAD 'BOTA!!! #6
Re: BAD \'BOTA!!!
This same problem happened to my B20. I took out the sediment bowl and cleaned it and i also jumped the tractor with some cables. I would also check the glow plug and the battery connections.
The Ben from MA /w3tcompact/icons/cool.gif
/ BAD 'BOTA!!!
Re: BAD \'BOTA!!!
Thanks for the information all.
Twinkle Toes, I don't have the manual and will write you if I can't fix things up with new fuel.
Gordon, I missed that discussion before and I am betting I have the same problem. Thanks for adding the link.
Kubota monkey, I will drain and clean the filter bowl and see what happens then.
The weather we are having has been crazy. I didn't have an additive in the fuel when it was parked and we had some cold weather. I am betting it jelled. I tried some additive I had around to see if I could get thing running. The additive was for gas and diesel but I don't think it said anything about anti-jel. I'll get the right stuff and try again.
Thank you
MarkV
/ BAD 'BOTA!!! #8
Re: BAD \'BOTA!!!
I live where it gets down to zero. When starting my Kubota B6200, if I don't glow them plugs good, it will not start.
Tom
/ BAD 'BOTA!!! #9
Re: BAD \'BOTA!!!
Thomas,
Does your B6200 have a heater,for it save alot on the engine starting day after day during cold weather.
/ BAD 'BOTA!!! #10
Re: BAD \'BOTA!!!
I’m hesitant to reply because I’m no expert and only offer a suggestion or two. The fact that your only had ½ tank full may be suspect for collecting condensation that is now frozen. When your tractor started and ran for a few seconds might be a burning up the fuel in the filter and pump then running dry.
Best of luck. Don’t know if I helped, but this board if full of knowledge and helpful people.
/ BAD 'BOTA!!!
Re: BAD \'BOTA!!!
Thanks for all the good ideas. I haven't made it back to my tractor yet this week. I did get some de-jelling additive and will give that a try. Weather is warmer here this week and that may help also.
Thanks again,
Mark
