BAD 'BOTA!!!
/ BAD 'BOTA!!! #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
BAD \'BOTA!!!
Need some help from you cold weather pros. My B21 (1998 model/ 580 hrs.)has never failed to start, until today./w3tcompact/icons/frown.gif It has not been started in two weeks and sat out in the cold during that time. (34F Hi, 10F Low) These are temps below normal for a Georgia tractor and I am not the best mechanic you have ever met.
When I had the problem I figured the fuel was the suspect. I added a stabilizer to the tank (1/2 full) but no luck. It would turn over and did run for 5-10 sec. but then died. Jumped it with the truck, a lot of turning over, but never fired up. Anyone have an idea where I should start looking?? I sure did hate to miss my once every five year chance to blade snow./w3tcompact/icons/smile.gif
Thanks
MarkV
/ BAD 'BOTA!!! #2
Re: BAD \'BOTA!!!
Mark,
Maybe you have jell fuel in the line.
Do you have fuel flowing to your filter pot..to check open your bleeder screws.
So you have a saftey switch hidden somewhere.
Thomas..NH /w3tcompact/icons/wink.gif
/ BAD 'BOTA!!!
Re: BAD \'BOTA!!!
Thanks Thomas, Sorry for being so slow, are we talking the glass bowl below the fuel filter? I don't think I have a bleed screw, but I can pull the bowl. If the fuel has jellied, will an additive make it OK or do I need to find away to drain the tank?
MarkV
/ BAD 'BOTA!!! #4
Re: BAD \'BOTA!!!
Mark,
First: no cold weather pro here and not because it ain't cold here./w3tcompact/icons/smile.gif
Do you have the workshop manual for the B21? If not, I can help by adding the trouble shooting tips from the manual for "engine does not start". Let me know. My first guess would be the same as yours, fuel. I would check the fuel filter and the fuel line next the injection nozzles for gelled fuel.
Al
/ BAD 'BOTA!!! #5
Re: BAD \'BOTA!!!
If the fuel has jelled then you will have to change the fuel filter and fill it with fresh fuel/conditioner mix. Here is a link to a thread a couple of weeks ago. It goes into detail and gives the link to powerservice. <font color=blue>my tractor wont start</font color=blue>
Hope this helps
Gordon
/ BAD 'BOTA!!! #6
Re: BAD \'BOTA!!!
This same problem happened to my B20. I took out the sediment bowl and cleaned it and i also jumped the tractor with some cables. I would also check the glow plug and the battery connections.
The Ben from MA /w3tcompact/icons/cool.gif
/ BAD 'BOTA!!!
Re: BAD \'BOTA!!!
Thanks for the information all.
Twinkle Toes, I don't have the manual and will write you if I can't fix things up with new fuel.
Gordon, I missed that discussion before and I am betting I have the same problem. Thanks for adding the link.
Kubota monkey, I will drain and clean the filter bowl and see what happens then.
The weather we are having has been crazy. I didn't have an additive in the fuel when it was parked and we had some cold weather. I am betting it jelled. I tried some additive I had around to see if I could get thing running. The additive was for gas and diesel but I don't think it said anything about anti-jel. I'll get the right stuff and try again.
Thank you
MarkV
/ BAD 'BOTA!!! #8
Re: BAD \'BOTA!!!
I live where it gets down to zero. When starting my Kubota B6200, if I don't glow them plugs good, it will not start.
Tom
/ BAD 'BOTA!!! #9
Re: BAD \'BOTA!!!
Thomas,
Does your B6200 have a heater,for it save alot on the engine starting day after day during cold weather.
/ BAD 'BOTA!!! #10
Re: BAD \'BOTA!!!
I’m hesitant to reply because I’m no expert and only offer a suggestion or two. The fact that your only had ½ tank full may be suspect for collecting condensation that is now frozen. When your tractor started and ran for a few seconds might be a burning up the fuel in the filter and pump then running dry.
Best of luck. Don’t know if I helped, but this board if full of knowledge and helpful people.
/ BAD 'BOTA!!!
Re: BAD \'BOTA!!!
Thanks for all the good ideas. I haven't made it back to my tractor yet this week. I did get some de-jelling additive and will give that a try. Weather is warmer here this week and that may help also.
Thanks again,
Mark
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
John Deere 7200 6R Planter (A66285)
John Deere 7200 6R...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
3ft Metal Star (A65583)
3ft Metal Star...
JMR Tree Boom Mini Skid Steer Attachment (A64553)
JMR Tree Boom Mini...
