Backing up a Gen Trailer
/ Backing up a Gen Trailer #81
Maybe instead towing, make it moveable either FEL pallet forks or 3pt forks or carry all.
/ Backing up a Gen Trailer #82
This unit is pretty simple to make in your shop. I made this one for a Gradall with wider forks. It's pretty easy to back a short tongue trailer, without breaking your neck.
/ Backing up a Gen Trailer #83
Do you people even read his posts?
He plainly stated this generator is P.T.O. powered & he wants it to REMAIN hooked up to the tractor PTO.
How many of you have PTO access from the front of your tractors or the FEL's ????
/ Backing up a Gen Trailer #84
I did read his posts. His primary concern was getting the thing parked. It's not that hard to reconnect a pto after the generator is where it needs to be.
/ Backing up a Gen Trailer #85
I doubt he dedicates the tractor to generator use and leaves it connected 100% of the time.
/ Backing up a Gen Trailer #86
This thread got me thinking about how I use my PTO generator on a trailer...
I use the trailer as a platform during operation, and wheel it by hand from the shed to the tractor operating location and back. I know the op states his age is a factor, but wheeling my 15kw unit is pretty easy, and I'm no spring chicken either.
I can see how backing the trailer up would be a plain, so maybe go with a 3 point, or use pallet forks to pick up the trailer when necessary.
/ Backing up a Gen Trailer #87
Mount it on a 3-pt. platform and junk the trailer! Would make it much handier!
Nope, I much prefer it to be trailered. Handy and more portable. At times I have used mine by just backing up to and connecting the PTO shaft not even bothering with the one hitch pin.
/ Backing up a Gen Trailer #88
I have one of those little generator trailers (using it for a sprayer), and it can indeed be tricky to to back up.
Hook two of them up and I can't even go three feet in a straight line.
/ Backing up a Gen Trailer #89
Well if he parked it on pallets in a field with some rounded-over drain plugs, then it would be easier to back up. ;)
/ Backing up a Gen Trailer #90
Hook two of them up and I can't even go three feet in a straight line.View attachment 839270
Is the OP using a 2 wheel trailer or a 4 wheel trailer?
I got what I think is a 4 wheel luggage trailer at auction that I need to try out. Unfortunately I only bought one, so no backing a triple.
There is something funky about the way the rear tongue and axle steers.
/ Backing up a Gen Trailer #91
It's not really a matter of how many wheels it has but if it's a common semi trailer or a pull (aka full) trailer.
Those extra pivot points is what gets me in trouble, especially with doubles. And I wouldn't even dream of trying to back up triples.
/ Backing up a Gen Trailer #92
I will say that for anyone who is really good at backing up semi trailers, getting a pull trailer and learning to back it up is an initially-humbling experience. I've been doing the latter the last 6-8 years, and have actually gotten very good at it, as I need to back one around a very tight 90-degree turn to where I park it. The only trouble now is when I hook up a boat trailer, which should be dead-easy to back around, I get my brain double-crossed again by the pull trailer!
I used to tease that I could do a slalom course in reverse at speed with a boat trailer, but after so many years with a pull trailer, I'm not sure that's true anymore. Everyone knows steering is reversed with a semi trailer, but with a pull trailer it's reversed a second time, so to speak. Easy once you get the hang of it, but going back and forth initially ruins any muscle memory, and puts you back to having to think about what you're doing.
/ Backing up a Gen Trailer #93
Some of those pull trailers (with a tongue) have pins to look them straight or chains to hold them straight when backing. Jon
/ Backing up a Gen Trailer #94
Going straight is pretty easy, actually. So is making a turn. It's swinging the thing back out of a hard turn, without stopping to pull forward and straighten out, that's the big challenge with these.
Once you get all of that, which you will (not impossible), then the next challenge is to do it without turning the tractor wheel over so hard that your rear inside tire spins ruining your lawn in wet autumn conditions. That's my current challenge, anyway.
As to backing up a generator, if I can do the above twice per month all winter long with 2000+ lb. of wood in a pull trailer, I can't imagine not being able to back up a generator on a semi trailer.
/ Backing up a Gen Trailer #95
Your skills with a pull trailer are very impressive, I think. I sure couldn't park it in such close quarters. Part of that is probably that I only use mine a couple of times per year.
One thing I'm very used to is backing up regular (semi) trailers, but...that only works well when I'm using the mirrors. As soon as I turn around to look, it goes sideways.
That's my secret weapon for being able to back up a pull trailer. By looking behind me my brain gets double crossed and it works much better.
/ Backing up a Gen Trailer #96
That's funny, as I know what you mean, but I'm the dead-opposite. I learned to back up looking behind me, and while I can do it with only mirrors if I have to, it's not nearly as easy for me.
Since so much of my trailering experience is with boats (moving boat trailers since before I could legally drive), I can say the worst is an empty boat trailer without a mast stand or whips visible from your mirrors. Totally blind, at least before backup cameras, until the think is well into a turn. Having a pickup truck hitch rigged so that you can pull the trailer with the tailgate down is key to backing an empty trailer down a ramp for boat retrieval.
<-- used to race dry-sailed boats every weekend
/ Backing up a Gen Trailer #99
Those are only 28 and 24 feet respectively. But noticeably taller than yours, even though the dry van has an 18" chop from stock.
Had a 40-foot gooseneck flatbed for a while, but now it's down to a 32', and the longest being the 38' toy hauler.
/ Backing up a Gen Trailer #100
Cool. That landscape trailer used for hauling logs is 20 feet. The larger boat trailer is something like 27-28 feet with mast down.
Here are some similar links:
