backhoe trenching operations
/ backhoe trenching operations #1
sonny101
Kioti CX2510
Hello all,
I have a Kioti CX2510. While trenching is it okay to lift the rear wheels slightly off the ground and push the tractor backward with the bucket so I don't have to keep going to the front of the tractor to relocate it, or will this put too much stress on the backhoe to tractor mounts ? Thank you.
Pocojo
/ backhoe trenching operations #2
That's acceptable. That's what I do.
/ backhoe trenching operations #3
Commercial machines are moved that way a LOT. If your hoe mounts won't handle that, then they are going to fail when you are digging.
Not familiar with your machine. How does the hoe fasten to the tractor?
/ backhoe trenching operations #4
/ backhoe trenching operations #5
If it is subframe mounted , you are fine .Kevin.
/ backhoe trenching operations #6
I agree. If the backhoe is on a strong subframe it is fine to move it around like that.
You don't want to do that with the old style universal 3pt mounted backhoes.
/ backhoe trenching operations #7
I move mine with the backhoe no problem
saves time jumping off the tractor etc
willy
/ backhoe trenching operations #8
Yep, do it anytime I'm using the BH. Over 200 hours.... no problem
/ backhoe trenching operations #9
I do it as well with the BH92 hoe on my Kubota and never had a problem.
I also use another trick to move the tractor from the backhoe seat. I bent up a length of rebar and clamped it to the HST pedal. Won't work on a gear tractor though.
/ backhoe trenching operations #10
Except that you are supposed to lift the rear wheels slightly with the backhoe stabilizers and the front wheels slightly with the loader bucket while digging, then raise the stabilizers and the bucket slightly to put the wheels back on the ground, and use the backhoe to roll the tractor forwards or backwards. If you use the backhoe to raise the wheels while trying to move the tractor, you can very easily tilt the tractor sideways toward a rollover.
/ backhoe trenching operations #11
If you think you’re accidentally going to roll the tractor sideways you’d hate to see me tipping my excavator sideways to shake the dirt off the top of the blade.
/ backhoe trenching operations #12
Almost any tractor, but especially with a loader or backhoe and no ROPS+seatbelt is full of ways to kill yourself.
I have been irritated by 'switching seats' on mine a bit, but not terribly because i don't do any real 'straight line' work with it. I do have a trencher, after all. Usually if im digging something im not going to be moving all that far during the process. So i think it depends how you use it, how much it matters. When i was trenching my 900ft water line the backhoe was fixing all the spots the trencher couldn't handle due to boulders, etc.
Ultimately i think i'd like to build an SSQA backhoe attachment for my small skid steer. A heck of a lot cheaper than a mini-x and should still be able to adjust position very easily.
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
60in. Work Bench (A65640)
60in. Work Bench...
2021 Ram ProMaster 3500 Box Truck, VIN # 3C7WRVLGXME588513 (A65563)
2021 Ram ProMaster...
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
JOHN DEERE BD1108 GRAIN DRILL (A64277)
JOHN DEERE BD1108...
