backhoe teeth pins
/ backhoe teeth pins #1
terramite t9
does anyone know what the backhoe teeth pin size are on a 2015 T9. are they roll pins? can i get them at hardware store?
/ backhoe teeth pins #2
If they are like the ones on my T9, they're a model 156 tooth (something like that) and I order them from a company called Romac.
doubleo are u talking about the pins or the teeth?
im wondering about the pins that hold the teeth on
/ backhoe teeth pins #6
As DoubleO said, the teeth and the pins are 156 size. I replaced the old rounded ones on my T9 bucket with new Hensley style teeth shortly after I got the machine. Made quite a difference when digging. The 156 pins used for the Hensley teeth are: DIAMETER: .375″ - LENGTH: 2.0″ . If you are going to try and drive the pins out, I recommend getting the correct size roll pin punch. It makes removal much easier.
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
JOHN DEERE 5510 TRACTOR (A64278)
JOHN DEERE 5510...
2022 SUN COUNTRY 53FT NEXT GEN T/A CAR CARRIER TRAILER (A67148)
2022 SUN COUNTRY...
