backhoe joystick
/ backhoe joystick #1
welderboy14
Surrey, BC
John Deere 325
hi
i'am trying to find the best joysticks for operating a backhoe. the ones i was
going to use are no longer available now:mad: heres a link to them it is just picther now (it was only the joystick on the end of the block)
Item# 314356 Sold Out | Northern Tool + Equipment
but thay did cost $89.99
i hope someone knows of a place
i was hoping only to spend max $200 on each joystick
note i live in B.C canada
thanks very much
welderboy14
p.s i know i should of posted this in the hydraulics fourm but it would not let me post for some reson:confused: i will post it in the hydraulic fourm when it works
/ backhoe joystick #4
So you are not going to have outriggers?
You want it to be Open Center, and possibly with the Power Beyond depending on how you are going to power/plumb it.
/ backhoe joystick
ok thanks
and the outriggers are going to be manual so i can cut down the cost
/ backhoe joystick #6
thanks for the links
i think i have found the ones i am going get Directional Control Valves 220-905 Detailed Information
for this jostick should i still get the closed center plug?
thanks
welderboy14
No you don't need the closed center plug. You will need one PB sleeve/fitting. The output from the PB port will go the input of the second valve, and both valves have to return to tank.
If you have 5 cyl, you will need 5 spools. Unless you combine the out riggers into one spool.
/ backhoe joystick
their is going to be no hydraulic outriggers
/ backhoe joystick #8
I used the stacked small prince valves and added there joy stick option, I had 6 valves two for out riggers and put them in the middle and single handles on them and joy sticks on the out side, (I think surplus center has them),
I think you can see them in this picture, this was one of the first test hook up I had done with the back hoe,
/ backhoe joystick #9
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2014 Ford Expedition SUV (A64557)
2014 Ford...
