backhoe joystick
/ backhoe joystick #1
welderboy14
Surrey, BC
John Deere 325
hi
i'am trying to find the best joysticks for operating a backhoe. the ones i was
going to use are no longer available now:mad: heres a link to them it is just picther now (it was only the joystick on the end of the block)
Item# 314356 Sold Out | Northern Tool + Equipment
but thay did cost $89.99
i hope someone knows of a place
i was hoping only to spend max $200 on each joystick
note i live in B.C canada
thanks very much
welderboy14
p.s i know i should of posted this in the hydraulics fourm but it would not let me post for some reson:confused: i will post it in the hydraulic fourm when it works
/ backhoe joystick #4
So you are not going to have outriggers?
You want it to be Open Center, and possibly with the Power Beyond depending on how you are going to power/plumb it.
/ backhoe joystick
ok thanks
and the outriggers are going to be manual so i can cut down the cost
/ backhoe joystick #6
thanks for the links
i think i have found the ones i am going get Directional Control Valves 220-905 Detailed Information
for this jostick should i still get the closed center plug?
thanks
welderboy14
No you don't need the closed center plug. You will need one PB sleeve/fitting. The output from the PB port will go the input of the second valve, and both valves have to return to tank.
If you have 5 cyl, you will need 5 spools. Unless you combine the out riggers into one spool.
/ backhoe joystick
their is going to be no hydraulic outriggers
/ backhoe joystick #8
I used the stacked small prince valves and added there joy stick option, I had 6 valves two for out riggers and put them in the middle and single handles on them and joy sticks on the out side, (I think surplus center has them),
I think you can see them in this picture, this was one of the first test hook up I had done with the back hoe,
/ backhoe joystick #9
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
(2) Rear Case 500 lb Wheel Weights (A66408)
(2) Rear Case 500...
Quick Attach Concrete Mixer (A65579)
Quick Attach...
Miscellaneous Tools & Exhaust Parts (A65579)
Miscellaneous...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
