Backblade upgrade!
/ Backblade upgrade! #1
Aquamoose
Platinum Member
Deer Park, WA
Branson 3520h
Well, that was a catchy title eh?
Anyhow, I was tired of jumping on & off my tractor to make angle adjustments on my backblade so I went and added a hydraulic cylinder! I had to cut off a portion of the bracket up front (at the base)so the 10” stroke cylinder would sit in the optimum position. It’s configured so if I need to rotate the blade 180°, I can just unhitch the rod end, swing both the blade & cylinder to the opposite side and refasten. Took it out today to plow snow and it worked very well but when adjusting the angle, I had to be light on the valve or it’ll jerk around so I’m planning to add an adjustable restricting valve to slow it down.
Bolts are 3/4”, spacers are brass to position the cylinder higher to allow free movement in full travel. Cleaned it up & repainted to make it nice again.
/ Backblade upgrade! #2
Nice, clean job - Aquamoose. Did you actually get enough snow there in DP to try out the blade?? I got a skinny inch here yesterday.
/ Backblade upgrade! #3
Good job, i will be using your idea for my back blade.
Yessir, about 4”.
/ Backblade upgrade! #8
Nice job. Very clean and professional looking.
Tilt was more important to me so I used my available hydulics for an adjustable tilt.
/ Backblade upgrade! #9
I'm starting to get the notion that having 3 remotes would be a good idea.
Could one steal a loader connection for this? Perhaps even a loader 3rd function to keep the bucket useable for gravel/dirt?
/ Backblade upgrade! #10
Yep, nice. But where did u have to go to add that?
It may be more feasible to put a diverter valve on one of the outlets in my opinion.
How much for the cylinder?
surpluscenter.com
It was $119.50.
9-12229-10 1.5X10X1 DA HYDRAULIC CYLINDER SWIVEL EYES 119.50
It wasn’t easy to find the right configuration since I wanted the base to stay fixed on the centerline and had to find the sweet spot for the other end so it would replicate the same configuration as if I was doing it manually. My measurements were literally down to the 1/16th of an inch to dial it in just right.
Hoses were customized to length by Spokane House of Hoses. Just wished I had factored in a spot for the restrictor valve.
/ Backblade upgrade! #14
I'm envisioning some sort of visual device that you can use to tell at a glance from the seat if the blade is perpendicular. Maybe a fixed window with a colored carousel attached to the pivot and you can see a particular color in the window indicating 0°
/ Backblade upgrade! #15
[snip]
Aquamoose, very nice work!
Rather than mounting an adjustable restrictor valve, I'd just throw in an $8 restrictor fitting from TSC: https://www.tractorsupply.com/tsc/p...restricted-orifice-8mp-8fpxr-tsc?cm_vc=-10005
It'll thread in line with what you have, and slow the cylinder response time way down.
The one I linked to is 1/2" NPT. Can't tell from your pic, but if you used 3/8" hose, they have one for 3/8" NPT as well: https://www.tractorsupply.com/tsc/p...restrictor-orifice-6mp-6fpxr-tsc?cm_vc=-10005
Or a magnetic sensor similar to those used for roll up doors? Sky’s the limit for anyone but for me, I just look back & observe. Besides, I like to watch my handiwork in operation.
BRILLIANT!!!!!! Thank you! I’m going to order one!
/ Backblade upgrade! #18
Nice...very nicely done. (y)
/ Backblade upgrade! #19
I know very little about hydraulics. Does the restrictor need to be on a particular line going to a double acting cylinder, or does one restrictor on either hose work?
This thread reminded me that I want to slow down the angling of my Land Pride blade.
/ Backblade upgrade! #20
How big/heavy is the tractor and how wide is the blade.
It's a nice fab job....but be careful with it. Real possibility of blowing a hose if you snag something with the edge of the blade with such a small cylinder.
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2009 IC Corporation School Bus, VIN # 4DRBUAAN39B694287 (A65563)
2009 IC...
INOP/NON-RUNNING EZ - GO Golf Cart (A65579)
INOP/NON-RUNNING...
Auger Cart (A65640)
Auger Cart (A65640)
2022 EZ-GO ELITE...
