B7800 Wheel Spacers
/ B7800 Wheel Spacers #21
Was that $250 each (times two for one on each side...$500), or per each pair? i.e. each one, or each pair? Any still available?
I dunno if cinckid ever checks in here anymore, but he hasn't posted in 3 &1/2 years. You could try to PM him and see if he responds. The factory Kubota spacers are available, which add a total of three inches to the width. When I bought mine a few years ago, I think the kit was around $300.
/ B7800 Wheel Spacers #22
Whats up with these spacers??? I want and need them!
please let me know!
thanks
/ B7800 Wheel Spacers #23
I wont to order rear wheel spacer for moy tractor kubota b7800 for stability and row in gardening.Please help with.
/ B7800 Wheel Spacers #24
Cost of the extensions were expensive - $250 each. That included the bolts for the extensions. The nice part is they can be removed to return the tractor to original condition. The Unverferth site did not have spacers to fit my tractor. I also foam filled all the tires, front and rear, which also helps with stability and prevents flats. You can run over anything, nails, thorns etc.
are they alum or steel.
/ B7800 Wheel Spacers #25
If you need someone to make them google freds wheel spacers. He makes them for trucks. I am sure if he can get the measurement he will be able to help. Very nice guy.
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
COMBINE RIM FOR JOHN DEERE (A63291)
COMBINE RIM FOR...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
