B7800 Rear hydraulics
   / B7800 Rear hydraulics #1
Bill Hoffman
Coventry, CT
Kubota B7800
I've been looking high and low and can't seem to find a way to put a 2 or 3 spool rear hydraulic set-up on my 7800. My dealer says only a one spool set-up is available. I'd like to do it as "factory installed" as is possible. Can anyone offer some suggestions?
Thanks,
Bill
   / B7800 Rear hydraulics #2
If you can get to my photos? I have a clean setup. The hoses are on the most part hidden and there is room for a small 3 spool valve, but you have to make you own levers and mounting bracket. I think I have just over $100.00 in mine and have 2 spools.
The reason I said if you get to my photos is because I can never get to other members photos. They need a link in ones profile. When I read what members post I like to read there profile and would like to look at there photos at the same time.
I also have a list of hoses and fittings that I used.
   / B7800 Rear hydraulics #3
While I'm no expert... if you can have one spool. you can have a dozen. It's all about the physical space that the valve would use. The B7800 has a power beyond port that is fairly easy to use.
Mike
   / B7800 Rear hydraulics #5
Bill the pictures are on there way.
   / B7800 Rear hydraulics #6
Kubota sells a rear remote kit for the B7800 that can have 1,2 or 3 spools. You order the base unit (1 spool) and add up to 2 additional spools if you wish.
   / B7800 Rear hydraulics #7
Can't find your photos?
   / B7800 Rear hydraulics #8
Highrpms, I well post what I have.
   / B7800 Rear hydraulics #9
Still no photos?
   / B7800 Rear hydraulics #10
I put 9 pictures on here and they are in post # 8.
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
