B7800 Rear hydraulics
   / B7800 Rear hydraulics #1
Bill Hoffman
Coventry, CT
Kubota B7800
I've been looking high and low and can't seem to find a way to put a 2 or 3 spool rear hydraulic set-up on my 7800. My dealer says only a one spool set-up is available. I'd like to do it as "factory installed" as is possible. Can anyone offer some suggestions?
Thanks,
Bill
   / B7800 Rear hydraulics #2
If you can get to my photos? I have a clean setup. The hoses are on the most part hidden and there is room for a small 3 spool valve, but you have to make you own levers and mounting bracket. I think I have just over $100.00 in mine and have 2 spools.
The reason I said if you get to my photos is because I can never get to other members photos. They need a link in ones profile. When I read what members post I like to read there profile and would like to look at there photos at the same time.
I also have a list of hoses and fittings that I used.
   / B7800 Rear hydraulics #3
While I'm no expert... if you can have one spool. you can have a dozen. It's all about the physical space that the valve would use. The B7800 has a power beyond port that is fairly easy to use.
Mike
   / B7800 Rear hydraulics #5
Bill the pictures are on there way.
   / B7800 Rear hydraulics #6
Kubota sells a rear remote kit for the B7800 that can have 1,2 or 3 spools. You order the base unit (1 spool) and add up to 2 additional spools if you wish.
   / B7800 Rear hydraulics #7
Can't find your photos?
   / B7800 Rear hydraulics #8
Highrpms, I well post what I have.
   / B7800 Rear hydraulics #9
Still no photos?
   / B7800 Rear hydraulics #10
I put 9 pictures on here and they are in post # 8.
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
