B7800 Rear hydraulics
   / B7800 Rear hydraulics #1
Bill Hoffman
Coventry, CT
Kubota B7800
I've been looking high and low and can't seem to find a way to put a 2 or 3 spool rear hydraulic set-up on my 7800. My dealer says only a one spool set-up is available. I'd like to do it as "factory installed" as is possible. Can anyone offer some suggestions?
Thanks,
Bill
   / B7800 Rear hydraulics #2
If you can get to my photos? I have a clean setup. The hoses are on the most part hidden and there is room for a small 3 spool valve, but you have to make you own levers and mounting bracket. I think I have just over $100.00 in mine and have 2 spools.
The reason I said if you get to my photos is because I can never get to other members photos. They need a link in ones profile. When I read what members post I like to read there profile and would like to look at there photos at the same time.
I also have a list of hoses and fittings that I used.
   / B7800 Rear hydraulics #3
While I'm no expert... if you can have one spool. you can have a dozen. It's all about the physical space that the valve would use. The B7800 has a power beyond port that is fairly easy to use.
Mike
   / B7800 Rear hydraulics #5
Bill the pictures are on there way.
   / B7800 Rear hydraulics #6
Kubota sells a rear remote kit for the B7800 that can have 1,2 or 3 spools. You order the base unit (1 spool) and add up to 2 additional spools if you wish.
   / B7800 Rear hydraulics #7
Can't find your photos?
   / B7800 Rear hydraulics #8
Highrpms, I well post what I have.
   / B7800 Rear hydraulics #9
Still no photos?
   / B7800 Rear hydraulics #10
I put 9 pictures on here and they are in post # 8.
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
