B7800 or L3400?
/ B7800 or L3400? #1
tgicountryboy
Northwest Missouri
I am fairly new to TBN, but have been reading advice off this site for a long time. I recently purchased 10 acres of rolling hills, no trees except along creek at back of property. 8 acres will be pasture (fescue, eventually native prairie), 2 acres of grass to mow. I also have a 200 foot gravel drive to keep up. I'm trying to save money. Would a B7800 work, or even a B7610? Also, I can't seem to reply to any messages on this site. Whenever I try, the system logs me out. Anyone else experienced this? Would sure like to take part in my own conversations.
/ B7800 or L3400? #3
Sounds a lot like my old setup. I ran a 5 foot Woods brushcutter on the back of my B7800. For the pastures though after initial cuts, I ran a 6 foot finishing mower. After a few years they looked really, really good. The 7800 was perfect for that lot, had the clearance to get into the woods, had the HP to run at a good speed cutting. I really sized that tractor right. (Pats himself on back).
-Mike Z. /forums/images/graemlins/grin.gif
/ B7800 or L3400? #4
I also have 10 acres and a 200 ft gravel driveway. My B3030 (same size/power as B7800, just more features) is the perfect size. I definitely didn't need anything bigger. Something smaller would do alot of what I do, but I would not want to bushhog with anything smaller than 5' cutting width, so again the B3030/B7800 seems "just right" to me.
/ B7800 or L3400? #5
Hi, I am looking for my first tractor to use on my 7 acres of heavily wooded hillside. A local dealer quoted the following prices, and I think I can go with either one, but can you tell me which one is a better deal for me in the long run in terms of performance and price as well as resale value?
B7800HSD 12,500
LA402 3400
BH75 6500
Total: 22,400
L3400HST, LA463, BH75 for 23,750
/ B7800 or L3400? #6
I think the B7800 or B3030 sounds like a fine package for you. I assume you are going to get a MMM for your mowing chores?
For starter's I think that th extra bit of cash is well spent on a B3030 over a B7800 - definately think about that. You get a lot of goodies for it - including a better 3PT valve. Well worth it IMHO.
I seriously considered the B7800/3030 and then let my dealer talk me into a L3400. It was the right move for my application. I have about 1 to 1.5 acres of lawn and about 13 of pasture and given what MMM's cost and the fact that I would have had to get turfs so as to not tear up the lawn, I was much better off getting a dedicated machine for the farm - the L3400 and now I'm shopping for a little riding mower for the yard.
I like the feel of the L series better than the B series - feels bigger and more solid. It is generally a heavier machine.
I hardly think you can go wrong with any one of these machines for your application - but if it is definatley going to include lawn mowing then go for the B instead of the L.
Can't hurt to mention again - I think the 3030 is a steal over the 7800. Only pass up on it if you have to :)
/ B7800 or L3400? #7
Thanks for the information. I think we will get a small riding mower just for mowing - it's less than an acre of grass, and it's cheaper than MMM. I also don't have to deal w/ attaching/detaching it. The rest of the 7 acres is wooded. I would like to use the tractor for snow removal, general clean up and maintenance, planting, moving logs and firewood, renovating a two stall barn into a cabin for kid's sleep over parties, etc. I would like a strong workhorse for this. When I compared the hydraulic output on B7800 and L3400, B7800 has 9.5 gpm and L3400 has 6.3 gpm. I don't exactly know what that means other than the higher the gpm, the stronger the hydraulic power. Have you had any issues w/ hydraulic attachments with L3400? I am buying FEL and back hoe. What about the price? Is this a reasonable quote? (dealer quote: BH75: $6500, LA463: $3500, L3400 $13750
/ B7800 or L3400? #8
</font><font color="blue" class="small">( <font color="blue"> </font> 9.5 gpm and L3400 has 6.3 gpm. I don't exactly know what that means other than the higher the gpm, the stronger the hydraulic power )</font> <font color="black"> </font>
GPM is gallons per minute. This is a measure of how fast the loader will be. The strength is determined by the pressure (PSI) rating and the size of the cylinders.
/ B7800 or L3400? #9
/ B7800 or L3400? #10
I believe the B7800 has one pump (dual pump) for both the power steering and the tractor hydraulics with total 9.5 gpm while the L3400 has 2 pumps, 3.8 gpm for PS and 6.3 for the tractor hydaulics. So to compare apples to apples the B7800 is 9.5 gpm and the L3400 is 3.8 + 6.3 = 10.1 gpm.
/ B7800 or L3400? #11
/ B7800 or L3400? #14
It looked to me based on the Kubota literature the B7800 had one "dual" pump. If that isn't true I sit corrected. But regardless of one pump or two the correct comparison between B7800 hydraulics and L3400 hydraulics is not 9.5gpm vs 6.3gpm. It is 9.5 v.s 10.1 (more or less).
/ B7800 or L3400? #15
2017 Hino 155 16ft. Box Truck (A59230)
2017 Hino 155...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
208316 (A58375)
208316 (A58375)
2019 Felling Trailers 9 Ton 18ft T/A Flatbed Equipment Trailer (A59230)
2019 Felling...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
Pittsburgh Heavy Duty Solid Steel Auto Ramps (A59230)
Pittsburgh Heavy...
