B7800 3pt minimum height
/ B7800 3pt minimum height #1
kody632
Wondering if there is a way to adjust the 3 pt arms so that they will go a little lower. seems when using the box blade it is just a little bit too high. I looked over it tonight but did not see any obvious adjustments?
/ B7800 3pt minimum height #2
The lowest the 3PT on my B7800 will go is 10 1/2" measuring from the floor to the center of the "eye" on the lower lift arms.
/ B7800 3pt minimum height #3
Something should be able to be adjusted to be able to loser them... have you asked your dealer about it?
Measured mine today, they are also 10.5"
Still haven't been able to figure out if I can get them to go lower... haven't asked the dealer yet either
/ B7800 3pt minimum height #5
Move upright rods into the front holes in the lower link arms..
/ B7800 3pt minimum height #6
I do not know that model but I think the arms are pulled up by the lift rods and they are splined on to the upper shafts. If you moved the arms 1 spline it would lower you arms, but I have never done it. Second idea If you made up a custom bracket where the lift arms connect on to the lower lift arms that would also lower the arms. I like my second idea best as it is the least intrusive.
Craig Clayton
/ B7800 3pt minimum height #7
Your lift links that connect to the lower arms have multiple holes and you can lower them that way!
/ B7800 3pt minimum height #8
THIS marks the lower lift links Art is talking about. You want them in hole #2 on both sides. That will lower the arms significantly.
/ B7800 3pt minimum height #9
Ditto. For those who wonder Kubota designed the front set of holes for maximum height/drop range, and the rear set for maximum lifting power. The bigger Kubotas have 3 sets of holes for this same purpose.
thanks to all for the reply... I'm a little embarrased that I over looked this, I was too focused linkage...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2022 FREIGHTLINER...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2008 THE MACHINE CO. THAWZALL H250 HEATER  (INOPERABLE) (A68842)
2008 THE MACHINE...
Lot Five (A3632137)
Lot Five (A3632137)
2011 FORD F-150 (INOPERABLE) (A67714)
2011 FORD F-150...
Metal Rooster Weather Vane (A66738)
Metal Rooster...
