B7510 steering issue
/ B7510 steering issue #1
armymp
Milton, WI
Kubota B7510
Hello Everyone,
My first post here is to ask a question regarding my B7510. I took delivery of it in July of 2004. Right away, I noticed that the steering felt 'choppy' when I run that tractor in high range. It sorta feels like the the power steering works intermittently. I called the dealer then, and they said to run it until next season, and bring it in next year if it does not stop.
Well, here we are in May, so I took it in. Dealer calls and says it is normal, and his stock 7610 does the same thing.
Anyone else notice this?
Thanks!
/ B7510 steering issue #2
My 7610 does it. I haven't worried about it but am watching it and paying attention to any changes or adverse effects.
Regards,
Kevin
/ B7510 steering issue #4
No such behavior from my new 7610 and, personally, I wouldn't consider it 'normal' either. I use one-finger to spin mine, smooth as butter.
/ B7510 steering issue #5
Check the fluid in the front axle. A plug by the left front tire (muffler/filter side).
I've felt things like that and the fluid was low.
/ B7510 steering issue #7
I had a B7500 and if I was working it hard in high gear the steering would chop.
Thanks for the replys.
Dave
Here's a follow up on the steering issue-I had a hard time convincing the technician that there was a problem. It turns out that he was not running it long enough for it to warm up.
The problem is a bad hydro pump. As the tractor warmed up, the hyrdo flow got restricted. A call to Kubota and a new pump is on the way.
/ B7510 steering issue #10
Doesn't it make you feel better when everyone says you are crazy and the doctor says, "No, you are not crazy"?
Glad you found the problem and Kubota is making it right!
Bill Tolle
/ B7510 steering issue #11
glad you got the dealer to find the problem. I won't hijack you thread, but mine is still in the shop 2 weeks this month, with a recurring dead battery.
regards,
Steve
2022 EZ-GO ELITE...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
Loader Brackets (A65640)
Loader Brackets...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
5000bu GRAIN BIN (A64277)
5000bu GRAIN BIN...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
