B7100 starts lumpy
   / B7100 starts lumpy #1
stevemt
B7100
hi all my B7100 starts lumpy after it warm up its fine. noticed it happen after I ran out of fuel run the glow for about 25 seconds and starts after about the 5 turn
   / B7100 starts lumpy #2
Might have a little bit of air in your fuel system that will take a while to work itself out, could also be cold weather.
   / B7100 starts lumpy #3
May have air bleeding in to the lines while its sitting. Look for fuel leaks on your lines. If it is leaking fuel air can get in through these leaks.
checked all of the fuel lines I'm staring to lean towards the glow plugs herad a story of the tip of a worn glow plug dropping off and going into the cylinder. don't know if that is an old wives tale or not. B7100 sits in a nice shed so the cold doesn't get into its bones
   / B7100 starts lumpy #5
Have you tried adjusting the throttle setting for start up?:)
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
