B3030 PITA
/ B3030 PITA #1
Sully2
Cincinnati, OH
Kubota B3030
Replaced my toplink today with one longer for the impliment Im using..and removing the top link pin ( at the tractor) is a PITA the size of a baseball field...:eek:
The lift arms are SO CLOSE they have to be fully rasied to get the SPECIAL SHORT top link pin OUT ( or back in ) and to top it all off..my "bracket" has a slight burr on the right side hole..on the inside edge..so that the pin slide thru the left hand side of the bracket..thru the rod end of the top link and then ya have to ..??..beat...pound..?..something..to get it all the way thru
I dont really want to have to remove the bracket from the tractor because Id have to re-install it and make sure it was torque PROPERLY...( ??) to make it right...so Im going to TRY and get into it with a mandrel mounted grinding wheel ( ???) and not only remove any burrs but also "polish" the ID's of the holes in the bracket and if I CAN...Im going to grind a chamfer on those hoes on both inside edges
What a PITA!!
/ B3030 PITA #3
40_acre_mule said:
Sounds like a good excuse to justify a newer, bigger tractor. :)
That's right, I'd load it right up and take it on down to the dealership ASAP and trade it in on a new Grand L model so you'd have more room to replace that toplink pin! :D
/ B3030 PITA
Might as well tade DOWN for a little BX tractor...since either one I couldnt use!...lol
I bought the largest that will fit thru the woods here ( and some places I still have to go around) with the most HP I could get.
/ B3030 PITA #5
I have a Grand L and the top link pin is tough on those too. It is also a two diameter step pin.
/ B3030 PITA #6
Also, the dipstick for the hydro fluid is mounted right next to the top link bracket. Kinda dumb to do that.
/ B3030 PITA
Well..I finally sat down and took a long look at the setup and tomorrow if it doesnt go to raining...Im going to pull the top link brackets off that critter and polish the link pin holes and chamfer the edges of the holes in the brackets to stop them ever getting burred up again. What a PITA
/ B3030 PITA
And the place where you fill the UDT..etc..to refill the tranny and such. Its in a "nice place"! Someone suffered from a BAD case of "recto cranial inversion" when they came up with that one!
/ B3030 PITA #9
I will trade you my B2910 for your B3030. The top link bracket has been used enough that putting pin in is not a chore. Must be some differences in these 2 tractors. I have to lower lower arms all the way down before installing an attachment to get top link pin in and out. Always install top link before installing an attachment when I remember. ;)
/ B3030 PITA
On mine when the lift arms are down, the pin wont even come close to getting out of the bracket. I can pull the clevis pin ( I think thats what its called?) and the top link pin will put BACK until the end is about even with the side of the bracket....not enough even to get a top link free even.
I thought that bracket was a single piece but I see now its TWO "L" shaped pieces so I'll have to wait for the rain to stop and Im pulling the one side off and polishing the ID of the hole and going to chamfer the "inside edge" of that hole to keep it from ever burring up again.
/ B3030 PITA #11
Going back aways. It was recommended that a heavy duty top link bracket be installed when using heavy rear attachments. do not know if it is available for the B3030. I bought mine because of the heavy rear blade I have. It also comes with the BL4690 backhoe.
You brackets sounds like the original 2 piece that came on my B2910. The heavy duty bracket is one piece and has more bolts holding it on.
/ B3030 PITA
I dont have any REALLY heavy impliments ( for a tractor to lift) but I have already bought heavier top links. I bent the rod end of the factory top link and called Kubota to see what they wanted for a new toplink...because I was told..by them..that the rod end COULDNT be unscrewed and replaced (??????) Kubota wanted $220 for a new toplink....:eek::eek::eek:
I went to TSC and bought a "China's Best" of the same length and much heavier for $19.95 and with the help of my farmer buddy got the factory link unscrewed and straightened and back into service.
( I should have realized that Kubota was going to give me a royal screwing on each and every part..but it didnt sink in until I had to pay $150 to replace a HEADLIGHT COVER!!!!!!:eek: ) which was the LAST Kubota item I'll ever buy!
Many many toplinks in the stable now and that way I can leave them on each impliment and dont have to keep re-adjusting them when I change impliments
The bracket on the tractor is more than heavy enough built though
/ B3030 PITA #13
I found a OEM top link on ebay. $20 including shipping.:cool: Looks better than original one.
I have 2 china top links. Plus a hydraulic top link. I only use the hydraulic top link on attachments that require adjustment while using them.
/ B3030 PITA #14
Try a 20" hunk of heavy chain.....much cheaper and it won't bend!
FWIW.......
Swmpbgy1
/ B3030 PITA
FWIW.......
Swmpbgy1
Kinda tough to adjust the attack angle on a back blade or a landscape rake with a chain?? I havent figured out yet how to PUSH a chain??
/ B3030 PITA #16
Sorry for the post.....your original post didn't really say what you were doing with the 3pt......just assumed for brush hogging......saw your implements in your sig.
Swmpbgy1
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2008 Ford E-250 Cargo Van (A66736)
2008 Ford E-250...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
