B2710 tachometer stopped working
/ B2710 tachometer stopped working #1
mangoland
Maui, Hawaii
Kubota B2710
RPMS are stuck at 0 /forums/images/graemlins/frown.gif
Does anyone have a schematic or some tips that can help me trace the tachometer wiring? What sort of sender does it use? I assume it is electrical. All the rest of the electrics are working OK, so I doubt it is a fuse.
Thanks,
Al
/ B2710 tachometer stopped working #2
Tachometer is run by a cable. It is not electronic. Check both ends of cable to make sure it is hooked up. You will have to pry up the gages with a screwdriver to get off of dash. Be careful, plastic is easily marked. Cable runs to front of engine. Upper right when looking from front of tractor. You may have a broken inner cable.
Yes, the inner cable snapped. It happened right at a sharp bend next to the instrument, only 101 hrs. Seems like it may not have been right to begin with. Ah well, easy fix.
/ B2710 tachometer stopped working #4
If it broke after only 101 hours, I would have the dealer replace both the cable and casing. The casing might have a burr inside of it that is causing the problem. If it is under warranty, why settle for anything less than a completely new service part.
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
2022 DEMCO KARKADDY X 9713093 CAR DOLLY (A64277)
2022 DEMCO...
2008 EZ-GO GAS GOLF CART (A63276)
2008 EZ-GO GAS...
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
40' New Container (A62679)
40' New Container...
