B2710 HSD
/ B2710 HSD #1
KubotaToy
SE Tennessee
Kubota LX331HSDC (hers) and L45 (mine), RTV1100 (hers)
Performed the 400 hr service on my B2710 yesterday which included changing the trans-hyd oil. I followed the owners manual to the letter, even the note that states do not operate the tractor immediately after changing the transmission oil. I waited about an hour and figured that was good to meet the "not immediately" warning. Would not start after several attempts. My question, is there a hyd. interlock with engine start if it has low hyd pressure? It started fine this morning.:confused:
/ B2710 HSD #2
I've got same tractor, no pressure interlock switch on mine. I'm guessing you did something with fuel system. Did you change/clean filter? I can't remember if there's a valve in the fuel line, it's been awhile since I did mine. Could you have left the fuel turned off somehow?
/ B2710 HSD #3
Did you change fuel filter or filters? Did you shut off petcock for fuel? Did you bleed air out of your fuel system?
DevilDog
/ B2710 HSD
Having screwed things up before and to keep troubleshooting easier when I do, I only do one maintanence item at a time and run or test the tractor. All, I did yesterday was changed hyd oil and filters. Would not start after. This was the first time I changed the hyd oil, dealer did it last time, I thought I may have missed something. Cleaned the fuel filter this morning after it cranked and ran fine. Maybe nothing after all.
2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
2024 Land Pride...
2006 FORD E350 CARGO VAN (A66091)
2006 FORD E350...
SDlanch SDLD25 Rubber Track Hydraulic Dumper (A64912)
SDlanch SDLD25...
2023 Kubota KX057-5 Midi Excavator (A66734)
2023 Kubota...
2021 Vermeer STR48 Hydraulic Trencher Attachment (A64912)
2021 Vermeer STR48...
2017 PETERBILT 579 (A67714)
2017 PETERBILT 579...
