B2650 Question about Charging after Light Bar Install
   / B2650 Question about Charging after Light Bar Install
Kyle,
That's great to hear. I'm glad you found it a simple install. Do you have the actual part number of that kit. That would go a long way with my dealer. Thanks for posting your results.
John
   / B2650 Question about Charging after Light Bar Install #22
Kit is B7324 and was $230 CDN.
   / B2650 Question about Charging after Light Bar Install #23
If you get a chance, snap a pic of the alternator mounted up, and a close up of the alternator data plate.
   / B2650 Question about Charging after Light Bar Install #24
Not sure what data you would like, something specific?
It is a pretty common alternator, used on a lot of applications, but for $230 CDN it made more sense to buy the kit from Kubota since it included the alternator, bracket, wiring, belt, and fasteners to do a very simple swap.
   / B2650 Question about Charging after Light Bar Install #25
Thanks for all the info with this thread!!! I have lights purchased and have been delayed on installing and, until this thread, never gave it a thought that this tractor doesn't have good power output from the stock Dynamo set-up. I purchased the B7324 kit on Friday and will install that before monkeying with any light's. I still may install a deep cycle / starter battery (i.e. Optima maybe) to ensure the system functions great, especially when using the lights with the engine off.
Thanks Kyle. I ordered my kit Saturday and should have it soon. Cost I was quoted was $190.00 US but I don't know if that's with or without tax. My dealer says that the description of the kit is for the B3200 but I'm pretty confident they're the same.
I'm pretty excited this kit exists. This seems like a pretty simple install so I look forward to getting the kit and getting it put in.
Thanks again for posting your results.
John
   / B2650 Question about Charging after Light Bar Install #27
Pretty easy kit to install, maybe should have taken pictures or did a video to show how easy. It must be for a few models as it comes with extra pieces like bolts, and a dipstick.
Hopefully everybody else's install goes as smoothly as mine did, post your results.
Kyle
   / B2650 Question about Charging after Light Bar Install #28
The B7324 kit is a wholegoods item and Messick's price is $233. The alternator in the kit is part number 16241-64013 and Messick's price is $279. Another example of Kubota's wholegoods prices being lower than parts prices.
   / B2650 Question about Charging after Light Bar Install #29
I would like to change mine out also, but hesitant until I can see a video to see exactly what goes where and how. Can someone please make a video and post it? Sure would help us mechanically challenged old folks. I used to just tear into things to fix, but as I've gotten older my confidence has lessened without good pics and videos.
   / B2650 Question about Charging after Light Bar Install #30
I'm away for work for a couple weeks, but if nobody else does a video or some good pics I'll do my best to put something together when I get back for anybody that's not sure about taking on the task.
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
CHAINSAW BENCH GRINDER (A58374)
CHAINSAW BENCH...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
