B2630 tractor stalling
/ B2630 tractor stalling #1
ezatu
So with all the snow here in New England I'm really depending on this tractor. Been great all winter but just ran into a problem today. Tractor starts up and idles fine however when I hit either the forward or reverse peddle it dies. I checked both air filters and they look clean. Actually removed them both and same problem exists. Fuel sould be OK since its been treated and machine is fine at idle.
I'm thinking dirty or clogged fuel filter. Just looking for comments and / or suggestions.
Thanks
Ed
/ B2630 tractor stalling #2
Change the fuel filter and make sure you bleed the system to expel the air, you then should be good to go. You didn't say how many hours you had on tractor or when it was serviced last.
DevilDog
/ B2630 tractor stalling #3
Check the fuel cap......frozen and or dirty and won't let air in....just a thought. Check out air filter as well
Sent from my iPhone using TractorByNet
Thanks guys. Changed fuel filter early last year but it does look a bit dirty. Will check fuel cap as well.
How would I expel air if I do change the fuel filter?
/ B2630 tractor stalling #6
Had the same problem a few years back on a B1700....Iced up fuel filter restricting fule flow. Engine would idle but die when more RPMs called for.
Thanks all. Just watched a YouTube on expelling air. Gonna attack the filter with a hair dryer later.
/ B2630 tractor stalling #8
Do you have a manual, after fuel filter change/clean the injector pump has to be bled .
DevilDo
g
/ B2630 tractor stalling #9
What about the seat safety switch?
It would behave exactly as described.
On my B3030,I can stand next to the running tractor and push on the hydro pedal ever so lightly and it will just barely creep.Push just a little bit more and the tractor shuts down.
Perhaps check/bypass the safety switch and try again.
Good Luck!
/ B2630 tractor stalling #10
After re=reading the OP problem description ( I assumed it was when engine speeds up) I agree with NUMBER TWO...sounds like a seat switch.
So it's 42 degrees today. Tractor started and ran just fine. There was an accumulation of snow and ice under the seat as I flip the seat up when I'm done running for the day. So not sure if there was some interference with the seat switch or the warmer weather dissolved any icing in the fuel line and /or filter. Bought a new fuel filter and will install next week as temp is supposed to rise to nearly 50. Also plan to cover seat area so snow or ice won't get in there.
Just wanted to thank all of those folks who provided suggestion and direction.
Thanks again Ed
2008 Big John 42' Log Trailer (A62613)
2008 Big John 42'...
Woods BW180HD Batwing Mower (A66285)
Woods BW180HD...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
