Oil & Fuel B2620 Oil Change... ugh!
/ B2620 Oil Change... ugh! #1
Evil the Weasel
Platinum Member
Central NY
Kubota B2620
Dear Kubota:
Why did you put the loader brace over my drain plug? I had to remove the MMM and the brace to do a simple job. :confused2:
/ B2620 Oil Change... ugh! #2
Dear Kubota:
I had the same problem so I bought a Quickdrain valve and replaced the drain plug. Put a small section of hose on the quickdrain, drilled a whole in the loader brace directly below the drain plug/quick drain and problem solved. Changing oil was neat clean fast and simple.
QuickOilDrainValve.com - the best way to change oil
/ B2620 Oil Change... ugh! #3
