Oil & Fuel B2620 Oil Change... ugh!
   / B2620 Oil Change... ugh! #1
Evil the Weasel
Central NY
Kubota B2620
Dear Kubota:
Why did you put the loader brace over my drain plug? I had to remove the MMM and the brace to do a simple job. :confused2:
   / B2620 Oil Change... ugh! #2
Dear Kubota:
I had the same problem so I bought a Quickdrain valve and replaced the drain plug. Put a small section of hose on the quickdrain, drilled a whole in the loader brace directly below the drain plug/quick drain and problem solved. Changing oil was neat clean fast and simple.
QuickOilDrainValve.com - the best way to change oil
   / B2620 Oil Change... ugh! #3
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
Takeuchi TB016 (A53317)
Takeuchi TB016...
296385 (A57192)
296385 (A57192)
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
