Oil & Fuel B2620 Oil Change... ugh!
   / B2620 Oil Change... ugh! #1
Evil the Weasel
Platinum Member
Central NY
Kubota B2620
Dear Kubota:
Why did you put the loader brace over my drain plug? I had to remove the MMM and the brace to do a simple job. :confused2:
   / B2620 Oil Change... ugh! #2
Dear Kubota:
I had the same problem so I bought a Quickdrain valve and replaced the drain plug. Put a small section of hose on the quickdrain, drilled a whole in the loader brace directly below the drain plug/quick drain and problem solved. Changing oil was neat clean fast and simple.
QuickOilDrainValve.com - the best way to change oil
   / B2620 Oil Change... ugh! #3
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
John Deere 5105M (A53317)
John Deere 5105M...
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
2023 Load Trailer (A55787)
2023 Load Trailer...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2016 Morbark Chipper (A55787)
2016 Morbark...
