Oil & Fuel B2620 Oil Change... ugh!
   / B2620 Oil Change... ugh! #1
Evil the Weasel
Central NY
Kubota B2620
Dear Kubota:
Why did you put the loader brace over my drain plug? I had to remove the MMM and the brace to do a simple job. :confused2:
   / B2620 Oil Change... ugh! #2
Dear Kubota:
I had the same problem so I bought a Quickdrain valve and replaced the drain plug. Put a small section of hose on the quickdrain, drilled a whole in the loader brace directly below the drain plug/quick drain and problem solved. Changing oil was neat clean fast and simple.
QuickOilDrainValve.com - the best way to change oil
   / B2620 Oil Change... ugh! #3
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
2019 Ford F-550 (A55973)
2019 Ford F-550...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
