B2320 work light question
/ B2320 work light question #1
miller3980
central ohio
kubota b2320
First i just want to say that I know absolutly nothing about electrical. Being color blind I try to avoid electrical work.
I am wanting to install 3 lights on my B2320. 2 forward and one backward. I know how to hook them up and run the wires but my question is am i trying to pull too much power? These will mainly be used this winter while plowing snow so the 3 lights, factory headlights, and at times flashers may be on at the same time.
single rear light.
Blazer Rear Mount Tractor Trapezoid Light - 0283941 | Tractor Supply Company
double front lights.
Blazer Multi Purpose Trapezoid Tractor Light - 0283917 | Tractor Supply Company
Also do I want the trapezoid or flood? The front two lights will be mounted high on the rops and the rear will probably be mounted low on the rops.
Thanks in advance for any help.
/ B2320 work light question #2
Not sure on the exact limit on current draw, but I've read it doesn't take many incandescent lamps to cross the line.
Just posting to let you know that are affordable LED utility light out there.
One example: Link
One example: Link
I really like those but the reviews don't sound good at all. Do you have them? If so would you recommend them? Everything else LED I found is out of my budget for this year.
/ B2320 work light question #5
the grote lights are great looking I know some other user have used them. I will have to work more OT before I buy them though I think they are close to 100.00 per.
/ B2320 work light question #6
55w/12v = 4.6 Amps each. Will your dynamo or ,less likely alternator, handle the load? Yes, but you may want to use front and rear independently.
As to the color blind issue, you might pick patterned wires, solid for hot and spiral striped for ground, for example Just a thought.
/ B2320 work light question #7
Like you, I know nothing about electrical either but wanted work lights. I had to bury a horse in the middle of the night without work lights so I purchased these Quick-On Work Light Kit the next day. I only ordered two but you can order three and Harry will wire them all together for you. They may be pricey but they work great and very easy to put on and take off. I took mine off today in about 30 seconds while working my brush cutter in the woods.
The first picture shows where to make the electrical connection to your existing wires on your tractor. It will just to the left of your PTO. The third picture shows the on/off toggle that can be mounted in various places and the fourth picture shows how the lights are mounted to the ROPS without any scratches.
/ B2320 work light question #8
Without the 40 amp high capacity alternator upgrade, I would be careful running more than 2 lights at a time. I don't remember the stock alternator output but it is really wimpy. I put 4 lights on my ROPS.....2 forward, 1 reverse and a strobe. I never run the headlights as they are poor at best. I only run the 2 new lights I installed. If I need the backup light for more than a few minutes, I will turn off the front facing lights.
I put 3 toggle switches in the little plastic thingie on the right fender behind the 4X4 and 3 pt levers. I also installed indicator lights on the thingie as well.
Great for blowing snow in the winter. Since it doesn't get dark til after 10 in the summer, I seldom need them.
Good Luck
Mike
/ B2320 work light question #9
The stock alternator output is 14amps max. i would recomend option alternator 40 amps output, also the headlight bulbs can be replaced with halongen bulbs (they just plug in)
/ B2320 work light question #10
/ B2320 work light question #11
stated something else were, and did not hit me, till i read your thread.
if you have a backhoe on back of tractor. you should opt for 2 rear work lights. and 2 front work lights.
reason for 2 rear work lights with backhoe. is because the backhoe will block majorty of the light, for were you want to dig.
1 rear work light works pretty nice, mainly for hooking / unhooking equipment. if ya go with 2 rear work lights. you can spread them out some (change angle of the lights). and get some descent lighting for a small little project. without dealing with extension cords, and other lights on stands.
Flood Lights + Work Lights | Emergency + Vehicle Lighting | Auto, SUV + Truck Accessories | Northern Tool + Equipment
some of the lights on this page. have a little U shape mount on them. with a bolt. you can pick up "pipe hanger" in plumbing section of most hardware stores, it comes in a role, and is metal, and has a bunch of holes through it.
wrap the stuff around your ROPS. and then snug the bolt that comes with light through a couple holes. and light should stay in place for a good long time. and still allow you to angle the light as needed. and if the bolt is just loose enough, you should be able to also twist the light around some to better position things as needed for various projects / doings.
tie wraps or rather zip ties. could be used to hold wiring to ROPS. so the cables do not get tangled around anything, including yourself.
the front work lights, for myself i have a front loader bucket, and do my best to stick them off the sides and pointed down were bucket front edge might be. this helps me from nocking the lights off if i go under a tree limb. but also gives me those very small extra inches to get more light down on the ground were the bucket will be. vs light being blocked by the front end loader "arms".
as other mentioned, you might want to check your "alternator" size. if unit did not come with say stocked extra work lights, or come with a cab. then most likely you have a small size alternator. and it could become very possibly of turning off your tractor and end up having a dead battery.
i am no help with "trapezoid" or "flood" one focus more light closer say 20 feet away, while the other i want to say fills the entire area with less light but covers a bigger area that is lighted up.
i am most likely wrong with above. going off the remember, which is gone.
i think i ended up going with trapezoid, for fronts, due to i wanted more light near me and within a smaller area for mowing so i could more easily see last path i made, and for dirt work with front loader and same with the back. note it though, i completely skipped idea of a spot light. i did not need lazer beem of light in one spot.
if it comes down to it, walmart, kmart, farm and fleet, farm king, or perhaps an autozone, or other car part store, should have some work lights on hand. and the boxes should have the pattern and distances it lights up on the boxes.
/ B2320 work light question #12
Here is some good reading on adding lights.
http://www.tractorbynet.com/forums/...ust-added-work-lights-2620-a.html#post1555355
I ended up using U bolts and put fuel line around them and clamped it around the rops. I tried magnets, but they weren't holding well enough. I have 2 switches so I can run the front 2 or rear 2 lights seperately.
If you plan on 3 lights and want to run them at the same time you might look for 35W lights instead of the 55W, or replace 55W with 35W bulbs, which I think someone mentioned.
Good Luck ! :)
