Someone here may know the answer right off, but why not check with a meter? Should take no time.Here is a question, i have been thinking about work lights as well, but my question is this. The connectors you are talking about under the right fender, are they connected to the factory light switch? So when i turn on the headlights the new lights i would install work?
Is it possible that some tractors don't come with the harness pre-wired? I cannot find any blue tape under or beside the right fender.
Does anyone know what the maximum amperage for lighting that can be tapped off of this location? I'm adding two lights (1.5A each).
I have a B2920, and looked under the right rear fender and missed it. My son went under with a flashlight and found it way up high. We connected the 3-light set-up from BXpanded and it worked fine. It operates independant from headlights
Found it, blue tape and all. Bad news is the BXpanded lights won't work as is. Wiring harness is too short. I'm going to use the light heads and the brackets and rewire it all.
What part of the harness is too short?
Any plans for a LED version of the work lights?
