Buying Advice B2320 wheel weights
/ B2320 wheel weights #1
GSmith4965
Bronze Member
Does kubota offer wheel weights for a b series tractor??? My rear wheels have the carraige bolt holes associated with whhel weights but I cant seem to locate them. Or an aftermarket source suggestion would be appreciated
/ B2320 wheel weights #2
Do you want wheel weights so you can remove them periodically? If not, have you considered RimGuard in the tires? More weight and less cost.
/ B2320 wheel weights #3
I asked the same question a year ago. Have not gotten any answers yet. Just really glad this winter was a whiff. I"ll be watching to see if you have any better luck.
/ B2320 wheel weights #4
Nothing available from Kubota but you might find used ones around that might fit.
Ballast box or some 3pt weight works well.:thumbsup:
/ B2320 wheel weights #5
The only wheel weights Kubota still makes for the B-series is the # B8048. They are about 140lbs for the pair and cost $250. However, according to Kubota they are only for the B2320DTN (narrow). My guess is they could be adapted to fit any of the B-series with 16" rear wheels.
There are also some aftermarket weight companies that make wheel weights that fit the B-series. IIRC the weights are about 60lb each and are around $60-70 each. Not sure who exactly makes them, but my dealer carried them.
/ B2320 wheel weights #6
Can anyone tell me if the Kubota B8048 weights "doughnut" shaped, or plates?
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2008 Ford E-250 Cargo Van (A59230)
2008 Ford E-250...
2013 Nissan Rouge SUV (A59231)
2013 Nissan Rouge...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
2009 Volkswagen Jetta Sedan (A59231)
2009 Volkswagen...
