Buying Advice B2320 wheel weights
   / B2320 wheel weights #1
GSmith4965
Does kubota offer wheel weights for a b series tractor??? My rear wheels have the carraige bolt holes associated with whhel weights but I cant seem to locate them. Or an aftermarket source suggestion would be appreciated
   / B2320 wheel weights #2
Do you want wheel weights so you can remove them periodically? If not, have you considered RimGuard in the tires? More weight and less cost.
   / B2320 wheel weights #3
I asked the same question a year ago. Have not gotten any answers yet. Just really glad this winter was a whiff. I"ll be watching to see if you have any better luck.
   / B2320 wheel weights #4
Nothing available from Kubota but you might find used ones around that might fit.
Ballast box or some 3pt weight works well.:thumbsup:
   / B2320 wheel weights #5
The only wheel weights Kubota still makes for the B-series is the # B8048. They are about 140lbs for the pair and cost $250. However, according to Kubota they are only for the B2320DTN (narrow). My guess is they could be adapted to fit any of the B-series with 16" rear wheels.
There are also some aftermarket weight companies that make wheel weights that fit the B-series. IIRC the weights are about 60lb each and are around $60-70 each. Not sure who exactly makes them, but my dealer carried them.
   / B2320 wheel weights #6
Can anyone tell me if the Kubota B8048 weights "doughnut" shaped, or plates?
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A56438)
FRESHLY...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
