Buying Advice B2320 wheel weights
   / B2320 wheel weights #1
GSmith4965
Does kubota offer wheel weights for a b series tractor??? My rear wheels have the carraige bolt holes associated with whhel weights but I cant seem to locate them. Or an aftermarket source suggestion would be appreciated
   / B2320 wheel weights #2
Do you want wheel weights so you can remove them periodically? If not, have you considered RimGuard in the tires? More weight and less cost.
   / B2320 wheel weights #3
I asked the same question a year ago. Have not gotten any answers yet. Just really glad this winter was a whiff. I"ll be watching to see if you have any better luck.
   / B2320 wheel weights #4
Nothing available from Kubota but you might find used ones around that might fit.
Ballast box or some 3pt weight works well.:thumbsup:
   / B2320 wheel weights #5
The only wheel weights Kubota still makes for the B-series is the # B8048. They are about 140lbs for the pair and cost $250. However, according to Kubota they are only for the B2320DTN (narrow). My guess is they could be adapted to fit any of the B-series with 16" rear wheels.
There are also some aftermarket weight companies that make wheel weights that fit the B-series. IIRC the weights are about 60lb each and are around $60-70 each. Not sure who exactly makes them, but my dealer carried them.
   / B2320 wheel weights #6
Can anyone tell me if the Kubota B8048 weights "doughnut" shaped, or plates?
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
John Deere 4520 (A60462)
John Deere 4520...
