B2320 3pt leaks down????!!!!!
/ B2320 3pt leaks down????!!!!! #21
Bump TTT for an resomable amswer ???
The answers provided that say it just the way it works are the correct ones. It's a royal PITA. My 2920 just turned 2 and I got a satisfaction questionnaire from Kubota. I went to great lengths to explain the quarter inching valve was useless. No doubt they will change the design based on my input:laughing::laughing::laughing:
/ B2320 3pt leaks down????!!!!! #22
I agree that the leaking down of the 3ph on my bx2660 ( one year old) is a pain in the butt when mowering or any time you lift the mower you have a hard time getting it back to the proper hight. I also added check chains I had seen them on old Ford tractors back in the 60's when I was working at the local Ford Dealer... V. T. F.
/ B2320 3pt leaks down????!!!!! #23
I looked on the Kubota website at the B2320 and under specifications it shows that the 3pt has position control???? Look on the second page. I am glad I saw this thread or else I would not know about this issue.
http://www.kubota.com/product/B2320/pdf/b_series_spec.pdf
Am I missing something since I always heard that the B2320 had position control...not a 1/4 inching valve.
/ B2320 3pt leaks down????!!!!! #24
The B2320N has position control. Thats the narrow version. I don't see why they don't offer it on the standard version since they already make it for that tractor. :confused2:
/ B2320 3pt leaks down????!!!!! #26
Is it possible to retrofit the position control to the 2320 or 2620 using the 2320Narrow parts? How expensive would that be?
/ B2320 3pt leaks down????!!!!! #27
On my B2320, the bucket does leak down over night. Not a problem for me.
The 3 point leaks down while mowing with a fairly heavy 4' King Kutter deck... This was an issue. Closing the 1/4 inching valve gets me through my mowing by maintaining position of the implement.
Hope this helps.
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
