B2320 3 point binding
/ B2320 3 point binding #11
The feedback lever binds up. It is 100% tied to this mechanism
This is not meant to be anything but helpful so please do not take my next comments wrong.
From a long way a way, it seems like you are focused on the symptoms, but not the cause.
An alternative to my suggestion of manually jacking up the lower arms, disconnect the lift links which ties the upper and lower lift arms together.
If in this condition, the feedback system operates properly, then the problem lies with the MMM.
You can remove the feedback rod and operate the 3 pt system, doing manually what the rod does automatically,.... relieves the application of pressure at the top of the lift arm stroke.
Dave M7040
I appreciate any and all help. I dont qualify as a mechanic or shade tree. Just tired of messing with it
Dave M7040
Ok I was able to get some free time again today. I removed the mmm and the binding continues at full up and full down.
Difference is at full down I can force the lever and it will still raise everything but it has a bind very similar to full up. I will take off all the moving parts one by one until there is nothing that I can rule out.
Thanks for the help and any suggestions keep them coming. No matter how obvious you may think it could be I wont be offended.
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2021 MULTIQUIP WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP...
Case Titan 3530 (A61307)
Case Titan 3530...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
