B21 fuel injection pump leaking, see pic, how to fix?
   / B21 fuel injection pump leaking, see pic, how to fix? #11
Yes do not turn those fittings on pump. Hold them still and turn line nut only. Maybe I should have used all caps. I can't stress that enough.
Thanks all, I have line wrenches I can use on them, if that doesn't fix it can I remove the barrel flange and replace the o-rings without removing the pump?
   / B21 fuel injection pump leaking, see pic, how to fix? #14
It’s not advised..
To many things can go wrong ...
   / B21 fuel injection pump leaking, see pic, how to fix? #16
I don’t recommend anyone going into their injection pump.. period.
Unless you’ve done it before and are VERY familiar with the insides and how it works.
But it’s your machine..
On THAT NOTE..
Yes u/I can lift the barrel and change the orings w the pump on the engine..
Where are u getting the orings.?? U HAVE TO use factory parts..
On THAT NOTE..
Thanks, I've rebuilt lots of contraptions and been a machinist for 37 years, I think I might try it, where would I find a part # for the factory o-rings?
   / B21 fuel injection pump leaking, see pic, how to fix? #18
Exactly.. ur not supposed find them.. because it’s not a diy project.
U can try searching your pump # for a breakdown.
   / B21 fuel injection pump leaking, see pic, how to fix? #19
There are some youtube videos on injector pump repair. There are some very fiddly parts (for lack of better description) that need to go in exact position. Have a look and see if you are up to the task.
2021 Bobcat T66 Skid Steer (A57453)
2021 Bobcat T66...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
2025 IRGC40 Mini 3 60v Electric Tricycle (A56859)
2025 IRGC40 Mini 3...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
1987 Chevrolet R3500 (A57148)
1987 Chevrolet...
1986 MURRAY WEST COAST STYLE RGN (A58214)
1986 MURRAY WEST...
