B21 fuel injection pump leaking, see pic, how to fix?
   / B21 fuel injection pump leaking, see pic, how to fix? #11
Yes do not turn those fittings on pump. Hold them still and turn line nut only. Maybe I should have used all caps. I can't stress that enough.
Thanks all, I have line wrenches I can use on them, if that doesn't fix it can I remove the barrel flange and replace the o-rings without removing the pump?
   / B21 fuel injection pump leaking, see pic, how to fix? #14
It’s not advised..
To many things can go wrong ...
   / B21 fuel injection pump leaking, see pic, how to fix? #16
I don’t recommend anyone going into their injection pump.. period.
Unless you’ve done it before and are VERY familiar with the insides and how it works.
But it’s your machine..
On THAT NOTE..
Yes u/I can lift the barrel and change the orings w the pump on the engine..
Where are u getting the orings.?? U HAVE TO use factory parts..
On THAT NOTE..
Thanks, I've rebuilt lots of contraptions and been a machinist for 37 years, I think I might try it, where would I find a part # for the factory o-rings?
   / B21 fuel injection pump leaking, see pic, how to fix? #18
Exactly.. ur not supposed find them.. because it’s not a diy project.
U can try searching your pump # for a breakdown.
   / B21 fuel injection pump leaking, see pic, how to fix? #19
There are some youtube videos on injector pump repair. There are some very fiddly parts (for lack of better description) that need to go in exact position. Have a look and see if you are up to the task.
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2019 Berky Weedo Amphi King 6450 (A56857)
2019 Berky Weedo...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
