B21 fuel injection pump leaking, see pic, how to fix?
   / B21 fuel injection pump leaking, see pic, how to fix? #11
Yes do not turn those fittings on pump. Hold them still and turn line nut only. Maybe I should have used all caps. I can't stress that enough.
Thanks all, I have line wrenches I can use on them, if that doesn't fix it can I remove the barrel flange and replace the o-rings without removing the pump?
   / B21 fuel injection pump leaking, see pic, how to fix? #14
It’s not advised..
To many things can go wrong ...
   / B21 fuel injection pump leaking, see pic, how to fix? #16
I don’t recommend anyone going into their injection pump.. period.
Unless you’ve done it before and are VERY familiar with the insides and how it works.
But it’s your machine..
On THAT NOTE..
Yes u/I can lift the barrel and change the orings w the pump on the engine..
Where are u getting the orings.?? U HAVE TO use factory parts..
On THAT NOTE..
Thanks, I've rebuilt lots of contraptions and been a machinist for 37 years, I think I might try it, where would I find a part # for the factory o-rings?
   / B21 fuel injection pump leaking, see pic, how to fix? #18
Exactly.. ur not supposed find them.. because it’s not a diy project.
U can try searching your pump # for a breakdown.
   / B21 fuel injection pump leaking, see pic, how to fix? #19
There are some youtube videos on injector pump repair. There are some very fiddly parts (for lack of better description) that need to go in exact position. Have a look and see if you are up to the task.
HARDEE SH-360-CO 5' DITCH BANK CUTTER (A52708)
HARDEE SH-360-CO...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2019 Elgin V2403-CR-T Broom Badger Sweeper, S/N V2903-7JV8496, Kubota Turbo Diesel Engine, High (A59076)
2019 Elgin...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
Honda EM 6500 SX Generator (A55973)
Honda EM 6500 SX...
461 (A52708)
461 (A52708)
