B21 fuel injection pump leaking, see pic, how to fix?
   / B21 fuel injection pump leaking, see pic, how to fix? #11
Yes do not turn those fittings on pump. Hold them still and turn line nut only. Maybe I should have used all caps. I can't stress that enough.
Thanks all, I have line wrenches I can use on them, if that doesn't fix it can I remove the barrel flange and replace the o-rings without removing the pump?
   / B21 fuel injection pump leaking, see pic, how to fix? #14
It’s not advised..
To many things can go wrong ...
   / B21 fuel injection pump leaking, see pic, how to fix? #16
I don’t recommend anyone going into their injection pump.. period.
Unless you’ve done it before and are VERY familiar with the insides and how it works.
But it’s your machine..
On THAT NOTE..
Yes u/I can lift the barrel and change the orings w the pump on the engine..
Where are u getting the orings.?? U HAVE TO use factory parts..
On THAT NOTE..
Thanks, I've rebuilt lots of contraptions and been a machinist for 37 years, I think I might try it, where would I find a part # for the factory o-rings?
   / B21 fuel injection pump leaking, see pic, how to fix? #18
Exactly.. ur not supposed find them.. because it’s not a diy project.
U can try searching your pump # for a breakdown.
   / B21 fuel injection pump leaking, see pic, how to fix? #19
There are some youtube videos on injector pump repair. There are some very fiddly parts (for lack of better description) that need to go in exact position. Have a look and see if you are up to the task.
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
40 ft. Shipping Container (A55973)
40 ft. Shipping...
Geismar powered by Stihl (A56435)
Geismar powered by...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Year: 2008 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 44,148 Plate: Body Type: 4 (A56858)
Year: 2008 Make...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
